araongao2015
How can I set the depth of ping pong ram when using config_dataflow
When I use config_dataflow, by default the pingpong ram is selected, but how can I set the depth of the memory.
can anyone give me some advice?
u4223374
Advisor
Advisor
The depth is big enough to hold the whole array that you're passing between functions. If you're passing a 1000 element array, the ping-pong buffer consists of two 1000-element RAMs. If you're passing a 2M-element image, then the ping-pong buffer is two 2M-element RAMs and you've probably run out of space on the chip.
balkris
it should be greater than frame size to avoid overflow and processing should be at frame rate.
Thanks and Regards
Balkrishan
