How do I add TLAST to AXI-Stream in HLS?
When configuring an HLS port as 'axis' it creates the base signals Tvalid, Tready. But what if I also want Tlast?
I know how to do that in Vivado, but is it possible in HLS?
Re: How do I add TLAST to AXI-Stream in HLS?
@archangel-lightworks
Use predefined type ap_axiu<32,1,1,1>
template<int D,int U,int TI,int TD>
struct ap_axiu{
ap_uint<D> data;
ap_uint<(D+7)/8> keep;
ap_uint<(D+7)/8> strb;
ap_uint<U> user;
ap_uint<1> last;
ap_uint<TI> id;
ap_uint<TD> dest;
== If this was helpful, please feel free to give Kudos, and close if it answers your question ==
Go for a `struct` with the members you would like to see, typically `data`, `keep`, `last`. This `struct` becomes the template argument of your IO `hls::stream`.
struct ap_axiu{
ap_uint<D> data;
ap_uint<U> user;
ap_uint<1> last;
ap_uint<TI> id;
ap_uint<TD> dest;
