wellwellwell
How do I make sure vivado_hls is on PATH?
I am working to use hls4ml with Vivado to for machine learning inference in FPGAs. I was following this quick start tutorial for hls4ml and got to the line
!hls4ml build -p my-hls-test -a
 and this is what it returns
2020-06-27 01:11:xx.xxxxxx: I tensorflow/stream_executor/platform/default/dso_loader.cc:44]
Successfully opened dynamic library libcudart.so.10.1
Loading configuration from my-hls-test/hls4ml_config.ymlVivado HLS installation not found. Make sure "vivado_hls" is on PATH.
I'm not exactly sure what it means by making sure "vivaldo_hls" is on PATH. I added the vivado_hls batch file to the Path environment variable. There was also a vivado_hls executable in
C:\Xilinx\Vivado\2020.1\bin\unwrapped\win64.o\vivado_hls
 which I tried adding but it still gave the same error. I am using Google Colab so I'm not sure if that would have anything to do with the issue. Any ideas?
viviany
What did you put into PATH?
I would expect "C:\Xilinx\Vivado\2020.1\bin\unwrapped\win64.o".
After setting up the PATH env var, have you closed the command prompt window and reopen it again to load the change in env var?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
calibra
@wellwellwell
Are you sure that vivado is installed in Colab ?
== If this was helpful, please feel free to give Kudos, and close if it answers your question ==
wellwellwell
Sorry, how exactly would I install Vivado in Collab? It is installed on my computer and I changed my Path environment variable to include the vivado_hls exe on my computer.
