How to add Arty board file in Vivado HLS 2015.4?
Hey,
I am facing trouble in adding the board file for the arty board in the Viv HLS2015.4. I downloaded the package off digilent website and was able to add the same for Vivado tool but somehow it does not work in HLS. I have copied the files and put them in the following folder: X:\Xilinx\Vivado_HLS\2015.4\common\technology\xilinx\<Arty Board Package Folder>. It worked in Vivado tool where I put this in the boards subfolder. Pls help.
The anticipated outcome is that I'd like to choose Arty as board in drop down menu when I want to "create new project".
pratham
shashwatssanghavi@gmail.com for HLS there is different procedure. Let me send .xml to you
-Pratham
pratham
-Pratham
pratham
shashwatssanghavi@gmail.com Please replace file from this location with attached one
C:\Xilinx\Vivado_HLS\2015.4\common\config
-Pratham
pratham
shashwatssanghavi@gmail.com Did you get the information you are looking for? If so please close this thread.
-Pratham
Anonymous
Not applicable
@pratham it's not really a helpful reply if you're passing around PM's with the file.  Can you attach it to your answer?
I'm having the same problem - I even added the board to the xml file by hand and get this error:
@E [HLS-70] Part 'xc7a35' is not installed.
Any ideas?
pratham
@Anonymous File is attached right there. Take a look
I think problem is part is not installed during installation.
-Pratham
jesko
I am wondering why the .xml file is added nowhere ... so I have to write this post, wait and hope someone provides it again.
lucas.ritter
Could you send me the procedure or the xml file that was used in solviing this problem?
I am having the same issue, and cannot find good documentation on the issue or documentation for hls at all.
Any help is greatly appreciated
jesko
the files snapshot ...
debrajr
There were some previous discussions also in these topics on other boards.
https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-Webpack-ARTY-Board-not-listed/td-p/682622
Debraj
deppenkaiser
i like to use the Arty-Board with HLS.
I can not download the solution XML-File. Can you pls. send me the needed XML-File or can you tell me the data, that i must include?
My current Version of HLS is 2016.2
Thank you...
Tags (3)
jesko
Probably you already have your answer. Just overread your question (2nd page) ...
You don't need the files, just use the correct device "xc7a35ticsg324-1L" and everything is fine.
daryon
Hi @pratham ,
Thanks for this helpful answer. It also solved my problem now.
Bests,
Daryon
sm7ed
I had to do this for the PYNQ-Z1 board. For Vivado HLS 2018.3, I added as another platform entry:
<board name="Xilinx_PYNQ-Z1" display_name="Xilinx PYNQ-Z1" family="zynq" part="xc7z020clg400-1" device="xc7z020" package="clg400" speedgrade="-1" vendor="pynq.io" />
in the file \Xilinx\Vivado\2018.3\common\config\VivadoHls_boards.xml
sm7ed
The directory is \Xilinx\Vivado\2018.3\common\config\VivadoHls_boards.xml  in newer versions
