Voyager
Voyager
How to add TID signal to axi4-stream directive
I'm using Vivado HLS 2016.3 and I've implemented a axi4-stream interface directive in a custom IP module, but only has been implemented with the most common axi stream signals (TDATA, TLAST, TVALID...etc) and I'd like to add the TID for different channel selection, how can I do that?
Many thanks in advance.
Teacher muzaffer
Re: How to add TID signal to axi4-stream directive
@joseer read ug902 section "AXI4-Stream Interfaces with Side-Channels"
Teacher muzaffer
