How to auto change the DDR's setting of ZYNQ_MPSOC for ZCU106's new DIMMs
Dear all,
I have got a ZCU106 recently and it was shipped with SODIMM MTA4ATF51264HZ-2G6E1 as this link https://www.xilinx.com/support/answers/71961.html says. However, I need to manually change the DDR's setting. Note that I run applications in the way of HLS --> Vivado Block Design --> SDK Standalone mode. Is there some easier way to do this or am I supposed to install some patches?
Looking for your kind reply.
Mentor
Mentor
Re: How to auto change the DDR's setting of ZYNQ_MPSOC for ZCU106's new DIMMs
Hi @crystal
What version do you use ?
Best regards,
Hi @watari ,
I'm using Vivado Design Suite 2018.3.
Mentor
Mentor
Hi @crystal
Would you refer the following AR ?
https://www.xilinx.com/support/answers/72113.html
Best regards,
HI @watari ,
Thank you for your reply. I have followed the link. However, as I have said, I run an application using standalone mode (jtag) in SDK. Consequently, I may not use the fsbl and PetaLinux temporarily.
Best Regards,
Mentor
Mentor
Hi @crystal
Did you use BOOT.BIN ?
If yes, would you run the following commands on linux ?
$ file BOOT.BIN
$ dumpimage -l BOOT.BIN
Best regards,
Hi @watari ,
Sorry, I don't use that file. Just launch SDK, download the bitstream in SDK and right-click the project --> Run as gdb.
Best Regards,
