How to create multiple input and output port in HLS (without AXIS).
Hi Folks,
I am doing with Vivado HLS, and I am working for image processing function.
How to create multiple Input and output ports.
Please suggest me regarding this.
I am using vivado HLS 2015.2.
Thanks and Best Regards
Vinod Sajjan
check chapter 4 interface synthesis
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug871-vivado-high-level-synthesis-tutorial.pdf
Thanks and Regards
Balkrishan
