01-17-2017 10:04 PM
When I try to add an IO register for the top-level scalar, there is a parameter -depth. But I find it can only be used for ap_fifo to set the depth of FIFO. So I want to know can I set the depth of register to create a cascaded registers.
01-18-2017 05:56 PM
It is all about implementing handshaking signals xxx_vld and xxx_ack (default ap_ctrl_hs mode).
With no register, handshaking is trivial.
With 1 register, handshaking is a bit more complicated (at any time there is either 0 or 1 value "in transit")
With >1 register depth, you'd need a proper FIFO to get the handshaking signals right.
VP
01-17-2017 10:16 PM
Isn't this just a register array? For that you just need to put an array on the interface.
01-17-2017 11:17 PM
Below is the GUI of adding IO register in Vivado HLS. I just want to add register to an IO. The main issue is how to set the depth of register. Here the -depth cannot be used to get this goal.
01-18-2017 05:56 PM
VP
01-19-2017 11:33 PM
