How to design a simple router in Vivado HLS?
I want to design a router which basically takes the AXI data response as input, checks the control signals, and accoridingly route the response to one module or another. I also want to write a test bench to test this functionality.
I'm not sure about how to get started. I'd appreciate any help in this regard.
Venky
Re: How to design a simple router in Vivado HLS?
Hi @kodukulav
Have you already looked at UG871
There are a large number of tutorials there that should help get you started.
Aoife
