How to draw lines on image in Vivado HLS?
I get some lines using HoughLines2 function, and I selected some and deleted them, I wanna draw the remaining lines on a white image,  and output it to show the result. so how can i do for it?
Scholar u4223374
Re: How to draw lines on image in Vivado HLS?
1028271706@qq.com Unfortunately there's no really good way to do it "fast".
Drawing one line on a streaming image is easy. Drawing up to N lines, where N is fairly small, is reasonably easy (you just have a bunch of "draw one line" blocks lined up). Drawing an undefined number of lines is not easy, because this requires an undefined (and possibly very large) amount of hardware.
The alternative (which allows an unlimited number of lines) is to rely on an off-chip memory buffer and just overwrite whichever pixels you want. However, with the limited caching available on an FPGA, this tends to be pretty slow.
回复: How to draw lines on image in Vivado HLS?
Hi 1028271706@qq.com ,
    Are you using the xfopencv honghlines function?
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Scholar u4223374
No, I just using the hls_video library.
I didn't get the point, what about drawing one or two lines (limited number of lines) is it possible using Vivado HLS?
