Observer saiwing_hit
How to generate reset API function in HLS ip?
In SDK, a HLS IP have many API functions like, "XHls_two_frame_Start", "XHls_two_frame_EnableAutoRestart", .... but it doesn't have a reset related funtion,  its CONTROL_BUS_ADDR_AP_CTRL reg doesn't have a reset bit either.
What should I do to have a reset funtion in SDK?
Thanks a lot if someone gives me some tips
Re: How to generate reset API function in HLS ip?
@saiwing_hit,
This is not necessarily my area of expertise - but I don't think it's standard practice for device drivers to have a reset function. I think if you really had to do this in practice, you would do a Release and then a new Initialize. But I don't think it's necessarily a good practice to send the reset signal to your hardware while it's initialized. I could be wrong, but I think this is why HLS does not provide a Reset function.
For the reset bit - you can control this behavior. Go to Solution in the menu, then select Solution Settings. Click "Add...", then use the dropdown to select "config_rtl". Then, set reset, reset_async, and reset_level as you prefer.
Nicholas Moellers
Xilinx Worldwide Technical Support
@saiwing_hit,
Nicholas Moellers
nmoeller, really thanks for your advice
just as your suggestion, we add reset signal through "config_rtl", but we have to add another ip to generate a resetting signal.
I am not in the field of FPGA, I still can't understand why it is unnecessary to make hls have a register to do this by itself. Anyway, the problem gets a solution. Thanks again!
