Newbie mostafakora
How to implement an array in different BRAMs (partitioning completely)to improve throughput
I have defined an static array of double with 100 elements in my top function.
Because I want to have maximum throughput I defined directive for partitioning
completely. Also I defined the resource as BRAM.
The problem is that finally vivado HLS uses only 2 or 4 BRAM and because of
that my reads and writes from and to BRAMs are going sequentially and the
iterative interval of the design increases. I try to keep it as low as possible up
to 8 or 10. but it goes to 60 or more.
please help me to find the problem.
Re: How to implement an array in different BRAMs (partitioning completely)to improve throughput
I am not an HLS expert, I read somewhere that reading & assigning a value in the same "run" could cause II to dramatically increase.
you may want to check whether HLS is creating this situation from your code. Sometimes the best way to describe something for HLS is not the way we would naturally describe it
G.W.,
NIST - Time Frequency metrology
Newbie mostafakora
Hi G.W;
Thanks for your comment,
I use directives for partitioning to tell Vivado_HLs to make the array by 100 BRAMs.
But it still does what it wants and use only 2 BRAMs.
I tried to use 8 BRAMs manually ( by using 8 arrays) and it works,
the II comes down very well.
