How to implement variables as Flip-Flops?
I am writing a code which uses very small fixed-point arrays (max. 4-by-4). I have read that HLS automatically implement arrays in BRAMs. The problem is that I need this code to be executed as fast as possible. Therefore, I would like these arrays, which some are inputs, some other outputs, and others just inside variables, to be implemented as Flip-Flops (what a hardware designer would do indeed).
How can I tell HLS that? Is there a directive to do so? I couldn't find one.
I have tried declaring the all the variables as static, which HLS interprets that I want them as distributed RAM (LUTRAM), but this is even slower than BRAM blocks.
Cerilet
For your variable use the following directive
#pragma HLS ARRAY_PARTITION variable=<your variable name> complete dim=1
and then again for dim=2 to completely partition your variable.
That way your variable would be implemented as registers and not RAM.
you can fully partition an array to make them implemented as registers (DFFs etc.).
Advisor
Advisor
@jehandad
You can just use dim=0 to partition every dimension in the array, rather than having one pragma for each dimension.
Dint knew that, thanks
