How to increase parallelization when executing this line of code?
When I implement this code, the substractions are done sequentially one after the other, not using more hardware even if I add 50 more lines of PWMx:
current = current + Ts_L * (Vtot -
			(PWM1==false?0:Vcap1) -
			(PWM2==false?0:Vcap2) -
			(PWM3==false?0:Vcap3) -
			(PWM4==false?0:Vcap4) -
			(PWM5==false?0:Vcap5) -
			R*current);
Does anyone know how can I parallelize this code?
Cerilet
Tags (3)
Voyager
Voyager
Re: How to increase parallelization when executing this line of code?
Hey Cerilet,
You can create a balanced tree where nodes with identical depth can execute at the same time ...
temp1 = (PWM1==false?0:Vcap1) + (PWM2==false?0:Vcap2);
temp2 = (PWM3==false?0:Vcap3) + (PWM4==false?0:Vcap4);
temp3 = (PWM5==false?0:Vcap5) + R*current;
temp4 = Vtot - temp3;
temp5 = temp1 + temp2;
current += Ts_L * (temp4 - temp5);
... this will reduce the cycle time required for the subtractions to log(n).
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
Voyager
Voyager
Hey Cerilet,
Hope this helps,
Herbert
Yes @hpoetzl, you are right.
I finally implemented an adder tree to easily change the number of operators. Here the code if anyone wants to use it.
num_cells = 8;
bool PWM[8]; double Vcap[8];
#pragma HLS RESOURCE variable=adder_tree core=RAM_S2P_LUTRAM double adder_tree[3][4]; #pragma HLS RESOURCE variable=adder_tree core=RAM_S2P_LUTRAM // Fully unrolled inner loop inner_loop: for(int i=0;i<num_cells/2;i++) #pragma HLS UNROLL adder_tree[num_ranks-1][i] = ((PWM[i*2])==false?0:(Vcap[i*2])) + ((PWM[i*2+1])==false?0:(Vcap[i*2+1])); // Build adder tree unsigned rank_size = num_ranks; first_loop: for(int adder_tree_rank=num_ranks-2;adder_tree_rank>=0;adder_tree_rank--) { rank_size=(rank_size+1)/2; // rank size // Fixed loop size so it can be unrolled second_loop: for(int jj=0;jj<((num_cells/2+1)/2);jj++) #pragma HLS UNROLL if(jj<rank_size) adder_tree[adder_tree_rank][jj] = adder_tree[adder_tree_rank+1][jj*2] + adder_tree[adder_tree_rank+1][jj*2+1]; }
Best regards,
Cerilet
Scholar u4223374
You could try something like this:
int PWM1_val = (PWM1 ? Vcap1 : 0);
int PWM2_val = (PWM2 ? Vcap2 : 0);
int PWM3_val = (PWM3 ? Vcap3 : 0);
int PWM4_val = (PWM4 ? Vcap4 : 0);
int PWM5_val = (PWM5 ? Vcap5 : 0);
current += Ts_L * (Vtot - PWM1_val - PWM2_val - PWM3_val - PWM4_val - PWM5_val - R*current);
Sometimes HLS just gets confused about required order of operations; this way it should be able to see that the initial calculations are all completely independent, and then the final line can be done in one cycle (assuming appropriate clock speeds).
