How to initialize class private data member to avoid power-on initialization?
Hello everybody
In my project, I want to generate RTL code with Vivado HLS (Version 2016.1). To do this, I want to use class members that represent internal states of my program. To simplify the analysis, I wrote a short code (shown below) to illustrate my problem with one class data member number: I wrote a Counter that adds with each call adds 1 to number, starting from 1.125 (I chose a float, as my class members are typically floats).
C-Simulation results are:
2.125
3.125
Now upon C-synthesis I get the following warning:
WARNING: [RTGEN 206-101] Register 'iCounter_number' is power-on initialization.
This is not what I want, because this means that number would be set to 0 at the beginning. I want that it to be set to 1.125.
How can I fix this ?
Note: I do not want to return the current value of number to the test bench file (as this would actually work, but result in other complications).
My example header files are:
// Counter.h
#ifndef COUNTER_H_
#define COUNTER_H_
class Counter
private:
float number;
public:
Counter();
~Counter();
float Counterfun(int);
#endif /* COUNTER_H_ */
// CounterTop.h
#ifndef COUNTERTOP_H_
#define COUNTERTOP_H_
float CounterTop(int);
#endif /* COUNTERTOP_H_ */
My example source files are:
// Counter.cpp
#include<iostream>
#include "Counter.h"
using namespace std;
Counter::Counter()
number = 1.125;
Counter::~Counter()
float Counter::Counterfun(int integer)
number = number + integer;
return number;
// CounterTop.cpp
#include "CounterTop.h"
float CounterTop(int integer)
static Counter iCounter;
return iCounter.Counterfun(integer);
My example test bench file is:
// CounterApp.cpp
#include<iostream>
int main()
float d;
int integer = 1;
for(int i = 0; i < 2; i++)
Counter i1Counter;
d = CounterTop(integer);
cout << d << endl;
Any help is appreciated.
Thank you!
Re: How to initialize class private data member to avoid power-on initialization?
Ok, thank you Jim.
I thought the warning is somehow related to the warning I get in C/RTL-Simulation: OPMODE 0110X0X with CARRYINSEL to DSP48 (not exact phrasing of the warning). But after adding config_rtl with reset all in Solution > Solution Settings > General the power-on initialization warning is gone, whereas the C/RTL-Simulation warning still persists, so probably this 2 problems are not related to each other.
Cheers,
Michael
Hi!
Did you try member initialization?
Counter::Counter() :
  number(1.125)
With kind regards,
Jacob
Hi Jacob
Thank you very much for your suggestion and your effort.
I tried member initialization now, but unfortunately I still get the same warning in Synthesis:
Further suggestions are highly appreciated.
Kind regards,
Michael
"power-on initialization" doesn't mean that the register is initialized to 0 during power on. It means the register is only reset during power-on. The reset value comes from your C source code. You will not be able to reset by asserting the reset signal to the block.
@migr wrote:
Hi Jacob
Kind regards,
Michael
Cheers,
Jim
Ok, thank you Jim.
Cheers,
Michael
