cerilet
How to inline library functions
I am using the HLS Linear Algebra library. I have two consecutive calls to a matrix multiplication, both take 32 clock cycles and the initiation interval is also 32.
I would like to use the pipeline directive in order to reduce the total latency, trying to start the second matrix multiplication before the first is finished. The problem is that neither of the two function calls do not appear in the directive pane.
How can I overcome this?
Thanks!
Cerilet
haggaie
I haven't tried it, but perhaps you can add the directive in a directives.tcl script manually.
haggaie
cerilet
Well, even though it is not recommended by Xilinx (it is written in the directives.tcl file "Please DO NOT edit it"), it worked.
It would be good if someone tells us why it is not good to modify this file manually and how we should add directives to functions that are in libraries.
Many thanks anyway!
Cerilet
Tags (3)
muzaffer
I think it's because Vivado also modifies it so it doesn't want any conflict. There is nothing inherently wrong with modifying it. Actually I as almost never use the gui, modifying the directives.tcl is what I mostly do.
