abregnsbo
How to prevent Vivado synthesis from changing ports on an instance
How do I prevent Vivado synthesis from changing ports on an instance ? During Vivado synthesis the tool add numerous ports and many name changes on a lower level instance. I need the ports unmodified compared to rtl so I can use the hierarchy (and everything below) for a gatelevel simulations.
In the VHDL architecture I added the KEEP_HIERARCHY attribute, and tried setting it to "yes" and "true", but this had no effect.
architecture rtl of maserati is
-- The keep_hierarchy is needed if we want to do gate-level simulation on the maserati hierarchy. Without this
-- attribute Vivado synthesis polutes the maserati hierarchy with numerous extra ports and extensive port renaming.
-- However below code does not work. Tried with both "yes" and "true".
attribute keep_hierarchy : string;
attribute keep_hierarchy of rtl : architecture is "true";
nithink
I meant the same when i mentioned that hierarchies will be retained. when you use flatten_hierarchy none, all the hierachies along with the ports will be retained.
You need to understand that if there are user defined datatypes, those will be bitblasted.
Nithin
nithink
If you want all the hierarchies to be retained, you can synthesize with
flatten_ierarchy = "none" option switch during synth_design
The RTL attributes works at that level. It doesn't propagate across the internal hierarchies
Nithin
abregnsbo
The problem is not that a hierarchy is removed. The hierarchy I want is retained, but Vivado synthesis makes numerious changes of the ports of that hierarchy.
nithink
Nithin
abregnsbo
Ahh ok. Will try that out.
