sharpmddr
How to print Stream data out ?
I am a new one to using the vivado HLS. I want to figure out the process of data transfer between PL and PS memory. I refer to an example on GitHub(https://github.com/lbielich/PLDataMoveSDSoC), but it only has printing process of memory address. I just want to use the assignment data to verify this process. I added the print function of the data value to this case, but when I print the output data(the value of “sofifo”), the output stream data are all zero. Replace the statement printf("sofifo[0] = %llx \r\n", (long long) sofifo[0]) with std::cout << " sofifo[0] = " << sofifo[0] << std::endl, the output value is still zero. I want to get the data value which are stored on the sofifo pointer. How can I get the correct value for printout this program? Thank you!!
#include <iostream>
#include <sds_lib.h>
#include <stdio.h>
#include <unistd.h>
#include <queue>
#include <fstream>
#include <unistd.h>
#include <stdint.h>
using namespace std;
#define BUF_SIZE (1024*8)
#define PL_DDR_ADDR 0x80000000
void stream_dma_pl( ap_uint<64> *din, ap_uint<64> *doutmig, int num_elements)
     for(int i = 0; i < num_elements; i++)
       #pragma HLS pipeline
       doutmig[i] = din[i];
void dma_pl_to_ps(ap_uint<128> *src, ap_uint<128> *dest, unsigned int length)
       for(int i = 0; i < length; i++)
       *dest++ = *src++;
void psddr_2_stream( ap_uint<64> *din, ap_uint<64> *dout, int num_elements)
      dout[i] = din[i];
int main(int argc, char **argv)
              //PL Buffers
              unsigned long long* plddr_buf = (unsigned long long*)sds_mmap((void *)(PL_DDR_ADDR ), BUF_SIZE, NULL);
              //Input Stream Sources
              ap_uint<64> *fifo = (ap_uint<64> *)sds_alloc(BUF_SIZE);
              //Output Stream Sink
              ap_uint<64> *sofifo = (ap_uint<64> *)sds_alloc(BUF_SIZE);
              //PS Contiguous Buffers
              ap_uint<128> * psddr_buf3 = (ap_uint<128> *)sds_alloc(BUF_SIZE);
              for(unsigned i = 0; i < 32; i++) //Initial input Stream Sources
                 fifo[i] = i;
              stream_dma_pl( fifo, (ap_uint<64> *)plddr_buf, BUF_SIZE/8);
              std::cout << " fifo[0] = " << fifo[0] << std::endl;
              std::cout << " fifo[1] = " << fifo[1] << std::endl;
              std::cout << " fifo[2] = " << fifo[2] << std::endl;
              printf("plddr_buf[0] = %llx \r\n", plddr_buf[0]);
              printf("plddr_buf[1] = %llx \r\n", plddr_buf[1]);
              printf("plddr_buf[2] = %llx \r\n", plddr_buf[2]);
              dma_pl_to_ps((ap_uint<128> *)plddr_buf, (ap_uint<128> *)psddr_buf3, BUF_SIZE/16);
              //Creates an output stream from received input
              psddr_2_stream((ap_uint<64> *)psddr_buf3, sofifo, BUF_SIZE/8);
              printf("psddr_buf3[0] = %llx \r\n", (long long) psddr_buf3[0]);
              printf("psddr_buf3[1] = %llx \r\n", (long long) (psddr_buf3[0]>>64));
              printf("sofifo[0] = %llx \r\n", (long long) sofifo[0]);
              printf("sofifo[1] = %llx \r\n", (long long) sofifo[1]);
The result is:
fifo[0] = 0
fifo[1] = 1
fifo[2] = 2
plddr_buf[0] = 5ccb2f07a
plddr_buf[1] = 5ccb2f07b
plddr_buf[2] = 5ccb2f07c
psddr_buf3[0] = 5ccb2f07a
psddr_buf3[0] = 5ccb2f07b
sofifo[0] = 0
sofifo[1] = 0
nmoeller
Hey @sharpmddr,
Could you try using the ap_uint class's member function to_uint64()? Example:
 std::cout << " sofifo[0] = " << sofifo[0].to_uint64() << std::endl
Please let me know if that helps.
Nicholas Moellers
Xilinx Adaptive Computing Tools
sharpmddr
Unfortunately, the output of this statement is still zero.
