How to read concurrently multiple consecutive elements from a multidimensional array?
let's say I have a multidimensional array, like this one:
data_t image_window0[3][3][512];
and I would like to read concurrently 16 consecutive elements.
Is this possible?
I tried to partition the array in dimension 0 by a factor of 16, but I got an error of illegal partition factor.
Is there a work around for achieving this?
Cheers,
Panos
Without proper software tools the hardware is unusable no matter how good and well designed it is.
Scholar u4223374
Re: How to read concurrently multiple consecutive elements from a multidimensional array?
Yes, it appears that your access patterns confuse it. If you pass in fchi/16 and we_pixel/16 instead of fchi and we_pixel, and perform the multiply inside the block (so HLS knows that it's definitely a multiple of 16) then it works fine:
typedef int mindex_t;
typedef int sindex_t;
typedef int lindex_t;
typedef int data_t;
void top(int fchi, int we_pixel, int image_window[3][3][512], data_t _weights[512], data_t mul_buffer[16]) {
#pragma HLS ARRAY_PARTITION variable=_weights dim=1 cyclic factor=16
#pragma HLS ARRAY_PARTITION variable=image_window dim=3 cyclic factor=16
#pragma HLS ARRAY_PARTITION variable=mul_buffer dim=1 complete
	for (int iw_h = 0; iw_h < 3; iw_h++) {
		for (int iw_w = 0; iw_w < 3; iw_w++) {
#pragma HLS PIPELINE II=1
			mindex_t fchi_tmp = fchi/16;
			lindex_t we_pixel_tmp = we_pixel/16;
			l_mul_chi: for ( sindex_t n = 0; n != 16; n++ )
				data_t tmp1 = image_window[ iw_h ][ iw_w ][ fchi_tmp * 16 + n ];
				data_t tmp2 = _weights[ we_pixel_tmp * 16 + n ];
				mul_buffer[n] = tmp1 * tmp2;
I don't know why. HLS should be able to figure this out for arbitrary fchi/we_pixel, even if it does take a whole lot of hardware to do the multiplexing.
Scholar u4223374
HLS array dimensions go [1][2][3]. If you want to partition only the last dimension, you need to use dim=3 (dim=0 means partition every dimension).
Edit: if you're only going to be reading at 16-element increments (eg. reading 0:15 or 32:47, but never 4:19 or 7:22) then an array reshape might work better for you. Just depends how clever HLS is at detecting the access pattern.
@u4223374
Thank you for the explanation. I misunderstood the dim=0 option as considering the multidimensional array [3][3][512] as [3x3x512] and then partitioning it.
But, you are correct as this confirms it:
"dim=<int>: Specifies which dimension of a multi-dimensional array to partition. Specified as an integer from 0 to N, for an array with N dimensions:
  • If a value of 0 is used, all dimensions of a multi-dimensional array are partitioned with the specified type and factor options."
Now, even if i reshape the last dimension of the array using the array reshape pragma, the HLS compiler cannot execute the code in parallel.
I'm trying multiply two arrays and get II=1:
	mindex_t fchi_n = fchi + n;
	lindex_t we_pixel_n = we_pixel + n;
	data_t tmp1 = image_window[ iw_h ][ iw_w ][ fchi_n ];
	data_t tmp2 = _weights[ we_pixel_n ];
even if I use the "array reshape block factor=16" at the third dimension of image_window and first dimension of _weights I cannot get II=1, even though i move in these two arrays by a factor of 16 each time.
Also using the array reshape pragma use a huge amount of resources (FFs and LUTs) meaning that even if I got II=1, the design is not implementable in my device.
Scholar u4223374
@pmousoul
Ah, I think I have the solution: you need a cyclic partition, not a block partition. A block partition will take your [3][3][512] RAM and split that into separate RAMs with elements:
[3][3][0:15]
[3][3][16:31]
[3][3][32:47]
and so on.
If it wants to read elements [0:15] it's going to have to do 16 reads from the first RAM, and none from the others - which is exactly what you don't want.
A cyclic partition will do:
[3][3][0,16,32,48,64...]
[3][3][1,17,33,49,65...]
[3][3][2,18,34,50,66...]
Reading from this, it'll be able to pull out one element from each RAM.
Try a cyclic partition and see how that goes.
@u4223374
I tried just now this:
set_directive_array_partition -type cyclic -factor 16 -dim 1 "hw_conv" _weights0
set_directive_array_partition -type cyclic -factor 16 -dim 3 "hw_conv" image_window0
but HLS still complains about:
INFO: [SCHED 204-61] Pipelining function 'mul'.
WARNING: [SCHED 204-69] Unable to schedule 'load' operation ('image_window_2_V_lo_2', ../../code/SqueezeNet1.1_C++/hconv_test_w16/hw_conv_helper.cpp:409) on array 'image_window_2_V' due to limited memory ports.
INFO: [SCHED 204-61] Pipelining result: Target II: 1, Final II: 8, Depth: 9.
showing at this line:
Maybe I make the access pattern too complex for HLS to understand it?
Scholar u4223374
typedef int data_t;
@u4223374
I would have never thought of this kind of coding would make it work. With your solution I don't even have to change my code!
Thank you very much!
