How to reduce the runtime of compilation during hardware emulation.
The compilation for hardware emulation takes a very long time.
I wonder
INFO: [HLS 200-10] ----------------------------------------------------------------
INFO: [HLS 200-42] -- Implementing module 'read_query_pca'
INFO: [SCHED 204-11] Starting scheduling ...
INFO: [SCHED 204-11] Finished scheduling.
INFO: [HLS 200-111]  Elapsed time: 28643.7 seconds; current allocated memory: 3.936 GB.
INFO: [BIND 205-100] Starting micro-architecture generation ...
INFO: [BIND 205-101] Performing variable lifetime analysis.
INFO: [BIND 205-101] Exploring resource sharing.
INFO: [BIND 205-101] Binding ...
INFO: [BIND 205-100] Finished micro-architecture generation.
INFO: [HLS 200-111]  Elapsed time: 4.29 seconds; current allocated memory: 3.936 GB.
INFO: [HLS 200-42] -- Implementing module 'read_query_or'
Just implementing module 'read_query_pca' taks 7 hours.
It's a very simple function.
void read_query_pca(const ap_uint<512>  *query_pca, D_point_pca *query_pca_oc){
//  #pragma HLS INLINE
    ap_uint<512> query_pca_temp;
    D_point_pca query_pca_oc_temp;
    #pragma HLS ARRAY_PARTITION variable=query_pca_oc_temp.x complete dim=0
    int loop_num = D_PCA/16;// each 512 bit including 16 float data
loop_rd_q_pca:for(int j=0; j<loop_num; j++){
        query_pca_temp = query_pca[j];
        for(int k=0; k<16; k++){
            #pragma HLS unroll
            unsigned int i_temp=query_pca_temp.range(32*(k+1) -1, 32*k);
            float f_temp=*(float*)(&i_temp);
            query_pca_oc_temp.x[j*16+k] = f_temp;
    *query_pca_oc = query_pca_oc_temp;
I guess the compiler is trying many different optimizing strategies for the function, so it takes a very long time.
I wonder is there a way that can reduce the implementing time.
Tags (2)
Re: How to reduce the runtime of compilation during hardware emulation.
Finally found this was cased by the partitionning of a very large array.
