How to replace DSP blocks for LUT in Expressions
I have realized that VIVADO HLS sometimes uses DSP blocks to instantiate Expressions, which are n-bit arithmetic circuits (fixed-point), commonly for, I suppose, loop control and memory addressing.
I need that Expressions be instantiated using LUTs instead of DSP blocks, so DSP blocks can be reserved for floating-point arithmetics.
I was trying to force VIVADO HLS to instantiate LUTs instead of DSP blocks using pragmas as ALLOCATION and RESOURCE with no success.
Any ideas?
Tags (4)
What is the expression and what is the RESOURCE directive you were tying?
Debraj
Dear Debraj,
Suppose I want to implement this particular version of a MAC operation,
#define M 42
#define N 21
void my_mac(float V[N][M], float Dv[M][N], float vDv[N])
     int32_t i;
     float acc;
     float accv[M+4];
     for (k=0; k<N; k++)
          accv[0] = 0;
          accv[1] = 0;
          accv[2] = 0;
          for (i=0; i<M; i++)
#pragma HLS PIPELINE
#pragma HLS UNROLL skip_exit_check factor=2
               accv[i+3] = accv[i] + V[k][i] * Dv[i][k];
          acc = accv[M] + accv[M+1] + accv[M+2];
          vDv[k] = 1 / acc;
Without additional pragmas, this circuit allocates 13 DSP for Instance and 2 DSP for Expression (VIVADO HLS 2014.2).
I tryied the following directives with no success:
#pragma HLS RESOURCE variable=i core=AddSub
// When it comes to variable i, only allocate combinational adders and subtractors
#pragma HLS ALLOCATION instances=FAddSub_fulldsp limit=3 core
// Only allocate 3 floating-point adder or subtractor implemented using only DSP48s
#pragma HLS ALLOCATION instances=FCmp limit=0 core
// Do no allocate 1 floating-point comparator.
Any ideas? :-)
Hi rodralez,
Did you manage to find a way for your problem. If yes, can you please share the solution?
Moreover, are you sure that the DSPs are used for expressions and not for multiplication between floats ?
Kind regards,
Abdul
Guys,
Check this thread to avoid using DSP for floating point operations. It would use LUT's & FF's instead.
http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/Matrix-multiplication-without-using-DSP/td-p/629898
Debraj
