mbence76
How to reset the DUT in the testbench code - to allow for independent tests in one go ?
I use Vitis HLS 2020.2  under Win10.
I would like to run multiple tests and reset the DUT (including static vars/arrays) between these tests.
I understand that the IP-core will have an ap_rst input, but my top C++ function does not.
I have searched the Forum and the User Guides - without success so far.
There must be a way to reset the DUT code between individual tests in the testbench.
Thank you very much
Miklos
dsakjl
Voyager
Voyager
Hi @mbence76 ,
I think one way you can do that is by defining a global variable to reset your code, assert that when you want to reset the core and read it inside the HLS function only when "__SYNTHESIS__" is not defined. For example:
static int a = 0;
#ifndef __SYNTHESIS__
if (GLOB_RESET == 1)
    a = 0;
#endif
Regards.
wave_rider
I also wonder the same problem....
dsakjl
Voyager
Voyager
Hi @mbence76 ,
static int a = 0;
    a = 0;
#endif
Regards.
wave_rider
that sounds like a good solution
thanks
mbence76
Good idea.  This way I will waste no HW resources.  Thank you.
