How to set :pragma HLS clock
I want to make my program to run faster. So i need to apply clock period to all functions in the design. What is procedure to follow ?
I have followed UG902 but i am not clear. Please explain me with examples.
Re: How to set :pragma HLS clock
For C and C++ designs, only a single clock is supported. For SystemC designs, multiple named clocks can be created and applied to different SC_MODULEs using the set_directive_clock command
For the C/C++ designs, if you connect the slow clock domain to the VHLS IP the tools should introduce the necessary circuits for clock rate conversion in the axi interconnect. .
Thanks and Regards
Balkrishan
Shall i use below syntax directly into C code
#pragma HLS clock domain=slow_clock.
How can i add the pragma directives into C codes. I am beginner to HLS please explain me step by step. It will be usable to me.
yes you can find examples here
https://www.xilinx.com/html_docs/xilinx2017_2/sdaccel_doc/topics/pragmas/ref-pragma_HLS_clock.html
Thanks and Regards
Balkrishan
Yes, i seen already.
I have program in C codes
Whether i need to give these commands in TCL window,
create_clock -period 15 fast_clk
create_clock -period 60 slow_clk
or else i need to give, pragma command inside the function of C codes.
both the places . you need to give pragma inside the c function and in tcl
Thanks and Regards
Balkrishan
@thaus_015
The create_clock will be useful only if you are using SystemC.
If you are using C/C++, you can speed up the modules by using PIPELINE/LATENCY directives on those particular modules.
Refer this link for syntax of PIPELINE/LATENCY pragmas: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_3/ug902-vivado-high-level-synthesis.pdf
You can also apply the directives by right-clicking the function in the Directive window on the right and clicking "Insert Directive".
Nupur
