eita
How to solve [XFORM 203-1403]?
Hi, everyone.
I'm getting error as below.
How to solve this error?
INFO: [XFORM 203-401] Performing if-conversion on hyperblock from (../src/Matching.cpp:55:3) to (../src/Matching.cpp:57:3) in function 'estSubPixel'... converting 4 basic blocks.
INFO: [XFORM 203-401] Performing if-conversion on hyperblock to (../src/Matching.cpp:233:2) in function 'Matching'... converting 508 basic blocks.
INFO: [XFORM 203-401] Performing if-conversion on hyperblock from (../src/Matching.cpp:285:2) to (../src/Matching.cpp:286:1) in function 'Matching'... converting 3 basic blocks.
INFO: [XFORM 203-602] Inlining function 'estSubPixel' into 'Matching' (../src/Matching.cpp:237) automatically.
INFO: [XFORM 203-11] Balancing expressions in function 'Matching' (../src/Matching.cpp:72)...4352 expression(s) balanced.
INFO: [HLS 200-111] Finished Pre-synthesis Time (s): cpu = 00:02:19 ; elapsed = 00:02:15 . Memory (MB): peak = 646.117 ; gain = 209.500 ; free physical = 34418 ; free virtual = 111743
WARNING: [ANALYSIS 214-1] Tool encounters 11054 load/store instructions to analyze which may result in long runtime.
ERROR: [XFORM 203-1403] Unsupported enormous number of load/store instructions: 'Matching' (../src/Matching.cpp:72) .
ERROR: [HLS 200-70] Failed building synthesis data model.
command 'ap_source' returned error code
    while executing
"source hls/Algorithm/solution1/csynth.tcl"
    invoked from within
"hls::main hls/Algorithm/solution1/csynth.tcl"
    ("uplevel" body line 1)
    invoked from within
"uplevel 1 hls::main {*}$args"
    (procedure "hls_proc" line 5)
    invoked from within
"hls_proc $argv"
Finished C synthesis.
I searched same issues in this forum, and found this posts.
Load-store-instructions-crash-ERROR-XFORM-203-1403
In this posts said, this error causes by large matrix, which uses unrolling loops.
But my code didn't use UNROLL directives.
I can't share my code, but my code is kind of image matching algorithm with two images.
By the default, this algorithm is uses 9x9 pixel matrix.
When I want to increase matrix size, like 11x11 or 13x13, this error was occured.
In the 11x11's log, the expression number is larger than 9x9.
Probably, I think this issue is caused by FPGA resources , or machine specs which running vivado-HLS.
chrisz
Hello @eita,
The developers continue to make Vivado HLS better by fixing bugs and improving the algorithms, which is what has happened between 2017.4 and 21018.2.  I am glad that it is working now in 2018.2.
Please let us know if you have any other questions,
Chris
chrisz
Hello @eita,
Which version of the HLS tool are you running?
  Which OS?
I would like to investigate this issue, so can you share your code via this post or PM.
  I would like to review the scheduler results and dive into the issue further.
Chris
eita
Hello @chrisz.
Thank you for reply.
Vivado HLS is 2017.4, and OS is Linux(CentOS6).
I can't share my code here(because it is confidential in business),
but I can share log message or get another logs and sample code.
My code sample is below.
This is main calculation process, it's become most large logic after hls.
If I set the  variable "WINDOW_W" to larger than 11, then ERROR: [XFORM 203-1403] was occured.
     label0:for(d=0; d<CW; d++)
         S1=0;
         S2=0;
         x=WINDOW_W-1;
         for(y=0; y<WINDOW_W; y++)
             sum = wbuf_r[x+MATCH_WID][y]+wbuf_l[x+d][y];
             S1 += sum;
             S2 += sum*sum;
         S1_BUF[d][0]=S1_BUF[d][0]+S1_BUF[d][1]+S1;
         S2_BUF[d][0]=S2_BUF[d][0]+S2_BUF[d][1]+S2;
         for(y=0; y<WINDOW_W-1; y++)
             S1_BUF[d][y+1]=S1_BUF[d][y+2];
             S2_BUF[d][y+1]=S2_BUF[d][y+2];
         S1_BUF[d][WINDOW_W]=S1;
         S2_BUF[d][WINDOW_W]=S2;
         costs[d] = ((WINDOW_W*WINDOW_W*S2_BUF[d][0]) + (S1_BUF[d][0]*S1_BUF[d][0]));
Eita
chrisz
Hello @eita,
How are 'S1_BUF' and 'S2_BUF' declared?
Chris
eita
Hello, @chrisz.
S1_BUF and S2_BUF is decreated below.
static i15_t S1_BUF[MATCH_LEN+MATCHWIDTH_EXPAND*2][WINDOW_W+1]={};
static ui22_t S2_BUF[MATCH_LEN+MATCHWIDTH_EXPAND*2][WINDOW_W+1]={};
MATCH_LEN, MATCHWIDTH,WINDOW_W is constant value, which defined in header file.
#define LINE_W				(IMGW/*3840*/)
#define WINDOW_W			(11)
#define MATCH_LEN			(128)
#define MATCHWIDTH_EXPAND	(2)
I was changing "WINDOW_W" value only.
When the value of "WINDOW_W" was 7 to 9 between, there is no errors, but larger than 9, Error [XFORM 203-1403] is occures.
Eita
eita
@chrisz
Additional information:
I tried to compile same source code on vivado HLS 2018.2.
Then, it's works and Error [XFORM 203-1403] wasn't occured.
I think something is difference, between 2017.4 and 2018.2.
But difficult to analysis this... (because I didn't touch any source code, and directives.)
Eita
chrisz
Hello @eita,
Chris
eita
Hello, @chrisz.
Thank you for everything.
Synthesized verilog file is available now, so no more question.
Eita
