futuristic
INT8 DSP48E1 HLS
Came across this white paper from Xilinx on utilizing DSP48E2 (18X27) to compute two INT8 multiplication operation in once cycle.
https://www.xilinx.com/support/documentation/white_papers/wp486-deep-learning-int8.pdf
Has anyone tried the same technique on DSP48E1(18X25) with HLS?
Cheers.
u4223374
Advisor
Advisor
@futuristic The following hasn't been tested, but it looks like a good start to me.
Using Xilinx's syntax, you're aiming to compute a*c and b*c (ie c is a common factor). Then for an unsigned operation it'd just be:
inline void mul2(ap_uint<8> a, ap_uint<8> b, ap_uint<8> c, ap_uint<16> * ac, ap_uint<16> * bc) {
    ap_uint<24> x = 0;
    x.range(23,16) = a;
    x.range(7,0) = b;
    ap_uint<32> product = x * c;
    *ac = product.range(31,16);
    *bc = product.range(15,0);
I haven't looked at the signed operation in detail, but it looks to be very similar.
u4223374
Advisor
Advisor
@futuristic HLS won't do it automatically, but it should be easy to implement it manually. Just write an inline function that does the two-element multiply.
futuristic
@u4223374 Could you share a snippet?
u4223374
Advisor
Advisor
    ap_uint<24> x = 0;
    x.range(23,16) = a;
    x.range(7,0) = b;
futuristic
@u4223374 That works great!
lwq2018
@u4223374  The unsigned operation works well, Can you provide an example of signed multiplication? Can only pack two unsigned numbers? Thank you!
