Participant edvinuzas
IP outputs 0s instead of a number.
I have been building a float matrix multiplier, which inputs and outputs ap_axiu<> type data and uses an union to reinterpret data. According to the User-Guide (UG902) pg.357 "Vivado HLS does not support access to a union through another variable. Using the same
union as the previous example, the following is not supported,"
for (int i = 0; i < 6; ++i)
if (i<3)
A[i] = intfp.intval.a + B[i];
else
A[i] = intfp.intval.b + B[i];
However, it may be explicitly re-coded as:
A[0] = intfp.intval.a + B[0];
A[1] = intfp.intval.a + B[1];
A[2] = intfp.intval.a + B[2];
A[3] = intfp.intval.b + B[3];
A[4] = intfp.intval.b + B[4];
A[5] = intfp.intval.b + B[5];
I understand this rule, therefore I have built a 2x2 matrix multiplier using this logic, which runs and only outputs [0][0], while everything else is left at "0".
The code for this is shown below:
#include "ap_axi_sdata.h"
#include "ap_fixed.h"
typedef union {
	unsigned int as_uint32;
	float as_float32;
} conversion_datatype;
typedef float float32;
typedef unsigned int uint32;
typedef ap_axiu<32,2,5,6> streamdata;
void noloop(streamdata A[2][2], streamdata B[2][2]){
#pragma HLS INTERFACE ap_ctrl_none port=return
#pragma HLS INTERFACE axis port=A
#pragma HLS INTERFACE axis port=B
	conversion_datatype
	temp_in00,
	temp_in01,
	temp_in10,
	temp_in11,
	temp_out00,
	temp_out01,
	temp_out10,
	temp_out11;
	int y, x;
	uint32 inputarray[2][2];
	float32 inputarray_float[2][2];
	float32 temp_array[2][2] = {
			{0, 0},
			{0, 0}
	float32 outputarray[2][2] = {
			{0, 0},
			{0, 0}
	uint32 outputarray_converted[2][2];
	float32 matrix1[2][2] = {
			{0.5, 0.4},
			{1.5, 2.1}
	float32 matrix2[2][2] = {
			{3.5, 0.8},
			{4.1, 3.25}
	//INPUT STAGE
	//INPUT STAGE
	//INPUT STAGE
	//input
	inputarray[0][0] = A[0][0].data;
	inputarray[0][1] = A[0][1].data;
	inputarray[1][0] = A[1][0].data;
	inputarray[1][1] = A[1][1].data;
	//conversion uint32 >> float
	temp_in00.as_uint32 = inputarray[0][0];
	temp_in01.as_uint32 = inputarray[0][1];
	temp_in10.as_uint32 = inputarray[1][0];
	temp_in11.as_uint32 = inputarray[1][1];
	inputarray_float[0][0] = temp_in00.as_float32;
	inputarray_float[0][1] = temp_in01.as_float32;
	inputarray_float[1][0] = temp_in10.as_float32;
	inputarray_float[1][1] = temp_in11.as_float32;
	//TRANSFORMATION STAGE
	// multiplication #1
	//line1
	outputarray[0][0] = (matrix1[0][0] * inputarray_float[0][0]) + (matrix1[0][1] * inputarray_float[1][0]);
	outputarray[0][1] = (matrix1[0][0] * inputarray_float[0][1]) + (matrix1[0][1] * inputarray_float[1][1]);
	//line2
	outputarray[1][0] = (matrix1[1][0] * inputarray_float[0][0]) + (matrix1[1][1] * inputarray_float[1][0]);
	outputarray[1][1] = (matrix1[1][0] * inputarray_float[0][1]) + (matrix1[1][1] * inputarray_float[1][1]);
	//OUTPUT STAGE
	//OUTPUT STAGE
	//OUTPUT STAGE
	//conversion float >>> uint32
	temp_out00.as_float32 = outputarray[0][0];
	temp_out01.as_float32 = outputarray[0][1];
	temp_out10.as_float32 = outputarray[1][0];
	temp_out11.as_float32 = outputarray[1][1];
	outputarray_converted[0][0] = temp_out00.as_uint32;
	outputarray_converted[0][1] = temp_out01.as_uint32;
	outputarray_converted[1][0] = temp_out10.as_uint32;
	outputarray_converted[1][1] = temp_out11.as_uint32;
	//output
    B[0][0].data = outputarray_converted[0][0];
    B[0][0].keep = A[0][0].keep;
    B[0][0].strb = A[0][0].strb;
    B[0][0].user = A[0][0].user;
    B[0][0].last = A[0][0].last;
    B[0][0].id = A[0][0].id;
    B[0][0].dest = A[0][0].dest;
    B[0][1].data = outputarray_converted[0][1];
    B[0][1].keep = A[0][1].keep;
    B[0][1].strb = A[0][1].strb;
    B[0][1].user = A[0][1].user;
    B[0][1].last = A[0][1].last;
    B[0][1].id = A[0][1].id;
    B[0][1].dest = A[0][1].dest;
    B[1][0].data = outputarray_converted[1][0];
    B[1][0].keep = A[1][0].keep;
    B[1][0].strb = A[1][0].strb;
    B[1][0].user = A[1][0].user;
    B[1][0].last = A[1][0].last;
    B[1][0].id = A[1][0].id;
    B[1][0].dest = A[1][0].dest;
    B[1][1].data = outputarray_converted[1][1];
    B[1][1].keep = A[1][1].keep;
    B[1][1].strb = A[1][1].strb;
    B[1][1].user = A[1][1].user;
    B[1][1].last = A[1][1].last;
    B[1][1].id = A[1][1].id;
    B[1][1].dest = A[1][1].dest;
By inputting [ 1.1   2.2  ]
                    [ 3.3   4.4  ].
I should receive:
[ 1.87   2.86  ]
[ 8.58  12.54 ]
but instead of that I receive:
[ 1.87    0  ]
[ 0         0  ]
Does anybody know what could be happening here?
Re: IP outputs 0s instead of a number.
You should prepare your output in a tmp variable and then assign it as a whole to the output array.
Olivier Trémois
XILINX EMEA DSP Specialist
I mean something like this:
tmp.data = outputarray_converted[0][0];
tmp.keep = A[0][0].keep;
tmp.strb = A[0][0].strb;
tmp.user = A[0][0].user;
tmp.last = A[0][0].last;
tmp.id = A[0][0].id;
tmp.dest = A[0][0].dest;
B[0][0] = tmp;
Olivier Trémois
Thank you, is the variable "tmp" a user-defined structure, union or ap_axiu<> type?
tmp is just a "streamdata", the type you defined at the beginning.
Olivier Trémois
