akokha
Identify an expression implemented by DSP resources in Vivado HLS synthesis
I am implementing a simple convolution using vivado. It contains six nested loops among which I parallelized the two innermost loops as the core of Multiply-and-Accumulate computations.
I expect it to use 105 DSP48E units after implementation. But, it uses 139 DSPs instead.
I checked the synthesis report and I found that VivadoHLS assigns 105 DSPs to multiplier and adder Instances (as I expect) and assigns the rest (34 DSPs) to Expressions.
I checked the expression details, I found that these 34 DSPs are used to implement expressions related to three variables, namely bound1_fu_1288_p2, bound2_fu_1378_p2bound_fu_1275_p2.
Is there any way to identify parts of my C++ code corresponding to these variables and/or set them to be implemented by other logic like LUT?
Thanks in advance,
Ali Kokhazadeh
nithink
Hi Ali,
  Did you check after Logic Synthesis if the DSP count matches. These are HLS estimates. You can go to Analysis view and try to cross probe from there to see which portion is inferring this one
Nithin
nithink
Hi Ali,
Nithin
akokha
Hi Nithin,
I had not performed Logic Synthesis (Using Export RTL option).
I tried it and found that the resource usage (including DSP usage) is lower than HLS estimates.
The DSP usage is 129 (10 units less than HLS estimates). It still uses 24 extra DSPs more than what I expected (i.e., 105). But for now, this overhead is acceptable for my design purpose.
In case of the need for less DSP usage overhead, I will try cross probe in Analysis view.
Thanks a lot,
Ali
