Visitor bilal_909
Image processing using zybo z7-20
Hi everyone, hope you are doing well
My final year  project is on zybo z7-20, I have to run correlation tracker and detect object in real time.
Now the problem is that due to some reasons I could not give much time to my FYP, and I don't have much time. For now, I have decided to do this project in VIVADO HLS but I am very new to HLS and  don't have much knowledge about IP design. Done some basic verilog codes on PL.
What I need is a good suggestion where I can learn quickly about IP Designs and C++ coding in HLS. Any good material?
Re: Image processing using zybo z7-20
Hi @bilal_909 ,
As you are new to Vivado HLS and will be trying to synthesize a c++ code using Vivado HLS, from HLS point of view as a baseline, I would suggest you to go through the below user guides from which you would be familiar with the Vivado HLS tool and the best practices.
Vivado HLS user guide -- UG 902
Vivado HLS tutorial -- UG 871
HLS Methodology User Guide
Visitor bilal_909
Hello Shameera, Thanks for the reply
I have already gone through some of the tutorials and I will study your suggested manuals as well
I am planning to use video library of HLS for correlation tracker, but I am not sure if it is possible to do this using video library as I could'nt find much help of this library on internet and I even don't know whether functions of this library are synthesizeable or not. Can you tell me that whether I am planning in right direction or not?
I would expect all HLS video functions to be synthesizable.
What you probably won't find is a function called "Corrrelation_Tracking_As_Bilal_Needs_For_His_FYP". We all would have a pile of PhDs if everything was that easy, man.
Visitor bilal_909
Hello   , your reply really made me smile
I have idea of this and your feelings as well and I know nothing is that simple. I need some help from experienced to learn video library as I could'nt find any good source. Or any type of help you can provide as I explained my problem. Any suggestion that will help me will be really appreciated
Hi @bilal_909
You could try using the xfOpenCV library available on our Github. There is more information about it here
We also have a number of tutorials about how to get started in HLS for video processing:
Video Beginner Series 14: Creating a Pattern Generator using HLS (Part 1)
Video Beginner Series 15: Creating a Pattern Generator using HLS (Part 2)
Video Beginner Series 17: Create a Video Crop IP using HLS (part 1)
Video Beginner Series 18: Create a Video Crop IP using HLS (part 2)
Aoife
