Installing Digilent Board on Vivado
I did this tutorial
https://reference.digilentinc.com/reference/software/vivado/board-files?redirect=1
Took the files and put them in the board_files folder but when I make a new project I still don't see them.I restarted Vivado.
Also is the code wrote in C++  better optimized then the one wrote in VHDL?
https://image.prntscr.com/image/zSjgfxEaTCi6M30bRLpCxA.png
https://image.prntscr.com/image/C3Uwfu9ZTDaSerNcQYNpDA.png
Scholar hbucher
Re: Installing Digilent Board on Vivado
@tester11 You are looking in HLS. Look for the menu option in Vivado. You likely have not installed any devices.
Scholar hbucher
@tester11 Make sure you are opening the right version of Vivado. Also, Vivado HLS has a different directory for boards. You have to copy to both.
C++/VHDL - short answer is, in general no. Most of the times it is actually impossible to write in C++ what is written in VHDL.  But writing VHDL often takes more time than writing C++ so in some cases the HLS compiler does a pretty decent job and you can get away with C++.
Thanks.Do you know how the xml definitions are generated for the  boards? I wanted to add an Arty board and only found the definition of the Zybo but the part ,device and package tags I don't think that match with the ones of an Arty Z7.
<board name="Zybo" display_name="Zybo" family="zynq" part="xc7z010clg400-1"  device="xc7z010" package="clg400" speedgrade="-1" vendor="digilentinc.com" />
Scholar hbucher
@tester11 Well I have a Zybo and I just installed 2017.4.
I downloaded the (new) definitions from Digilent (https://reference.digilentinc.com/reference/software/vivado/board-files)
Then unzipped the contents of the board_files folder inside the correct location in Vivado.
I can see the Digilent boards now.
I did the same.The second image is from Vivado? I have a different interface and I checked only in  the Vivado HLS
Scholar hbucher
@tester11 I think the board files are generated manually.
Also, make sure that you installed the devices you want when you installed Vivado.
Use "Add Design Tools or Devices..." to verify
Scholar hbucher
@tester11 You are right - I cannot see it inside Vivado HLS even though I installed it in Vivado.
That said, in Vivado HLS you don't need the board file because it only uses the device part.
I usually find the Part number in Vivado (in Project Summary or Create new project) and search for it in the parts list.
Seems that I have the basic version of Vivado.
I can't find anything even in the Part tab
Scholar hbucher
I saw them and made the xml for HLS.
Looks like a rough start for me.
Thanks for your time
Scholar hbucher
@tester11 I found that doing things non-standard way is a rocky road, even if it looks more correct.
Observer chainastole
@ hbucher Why board file is of no use when working with Vivado HLS? I have an original problem similar to this thread problem and duplicated at https://forum.digilentinc.com/topic/2068-arty-board-with-vivado-hls/ and https://forums.xilinx.com/t5/High-Level-Synthesis-HLS/Zybo-Board-Files-for-HLS/m-p/1038688#M18596.
If the board file is really of no use, I'll then concentrate on finding the right part for Arty-Z7020 to enter design.
@hbucher--- Why "... in Vivado HLS you don't need the board file because it only uses the device part"? I am asking because I try implementing some lab in HLS, which I am completely new to. Until now I experimented with RTL entry flow, which do needed board awareness. This was quite logical for me because I tinkered with on-board buttons and LEDs. Would appreciate you explain your statement.
