kodukulav
Intercepting AXI read transactions
I want to write a simple interceptor block in HLS, which will intercept a AXI read transaction from DPU to DDR, and figure out whether that transaction is within some known address range or not. I also want to write a testbench to verify this process.
I want to eventually integrate this HLS module into SDSoC to work with reVISION stack.
I'm not sure how to get started on this. I'd appreciate any pointers in this regard.
Venky
scampbell
Hello @kodukulav ,
HLS provides the ability to add AXI functionality on the interface to allow for the connection to AXI signaling in the larger design. However, inside the C++ code, there is unfortunately not a method to access these signals. With AXIM you can specify the base address as well as an offset via a separate port, or via the AXI Lite interface, but again, these signals are not available to the C++ logic used to create the IP. I think in this case you would need to create a wrapper that interfaces with the AXI system, then feed the AXI based signals to/from the HLS IP via dedicated ports of a ap_memory type interface. OK, I appologize this functionality you desire isn't available, but if you do have any other questions/comments please let us know.
Scott
kodukulav
Thanks @scampbell  for your response. I'll try that out and see
aoifem
Hi @kodukulav
Do you have any update on this?
Aoife
**~ Got a minute? Answer our Vitis HLS survey here! ~**
kodukulav
@aoifem @scampbell
I'm trying to get a simple pass through logic to work. I realized that while there is m_axi, there is not s_axi. I think s_axi needs to be implemented as a ap_memory interface.
I think the pass-through is going to work. However, if I want to implement the functionality that I need, I need to access the AWADDR line in the interface. I couldn't find any similar examples. Can you help me in this regard?
