Scholar u4223374
Is this a bug or expected behaviour?
Hello everyone,
Just testing a tiny bit of code in HLS and found this:
#include <ap_int.h>
typedef ap_uint<1> uint1;
void test_uint1() {
	uint1 y = 1;
	uint1 z = 1;
	uint1 w = y && (~z);
	printf("Y = %d\nZ = %d\nW = %d\n",(int) y, (int) z, (int) w);
The result:
Y = 1
Z = 1
W = 1
Unless I've misunderstood it completely, W = 0 would be correct. ~z should (according to UG902) return an ap_uint<1> value, which should be zero (since z is 1). Anything AND-ed with zero will be zero. Using a logical NOT instead of a bitwise NOT gives correct behaviour, although for a uint1 value you'd expect that they'd be equivalent. If I put an intermediate value in there (ie "uint1 x = ~z; w = y && x;") then I also get correct behaviour.
It's not a huge problem (easy to just use a logical NOT) but interesting and potentially worth the time that it'll take someone to fix it.
Re: Is this a bug or expected behaviour?
Hi @u4223374,
Yes it looks like a tool issue because if you cast the result of ~z into a uint1 it works:
uint1 w = y && (uint1)(~z);
So the operator ~ does not seems to return bitwise-NOT of z with the same width and signedness.
I will ask development to fix this.
Florent
Florent
Hi @u4223374,
Florent
Florent
Scholar u4223374
Hi @florentw,
Great! That's good to hear. I'll be awaiting a fix in HLS 2016.4!
Cheers,
Evan
Hi @u4223374,
Just to clarify, I cannot guaranty in which release it will be fixed. This seems to be a small fix so it could be resolved in 2016.4 but there are no guaranty.
Florent
Florent
Scholar u4223374
@florentw
Thanks for the clarification. Will there be a note about the bug being fixed (eg. in UG902) when that happens, or should I just test the same in each version of HLS until it works?
Hi @u4223374,
I will try to remember to update the post when I will have verified the fix.
If I forgot, please just send me an PM.
PS: The fix should not be in 2016.4
Florent
Florent
