Latch function outputs after valid
I've got a function that returns multiple outputs (12 outputs, but I've shown three below as example):
void function(int24 din, int32 *dout_A, int32 *dout_B, int32 *dout_C)
This synthesizes to the following VHDL port map:
    dout_A : OUT STD_LOGIC_VECTOR (31 downto 0);
    dout_A_ap_vld : OUT STD_LOGIC;
    dout_B : OUT STD_LOGIC_VECTOR (31 downto 0);
    dout_B_ap_vld : OUT STD_LOGIC;
    dout_C : OUT STD_LOGIC_VECTOR (31 downto 0);
    dout_C_ap_vld : OUT STD_LOGIC;
With many outputs, the number of valid signals to manage gets cumbersome.  Also I notice that dout_A is only valid when dout_A_ap_vld is high, but immediately after that the dout_A value can change to something meaningless.  So I must be very careful to latch exactly when the valid goes high, not a few clocks later.
The following would make my life much easier.  Possible with HLS using directives or otherwise?
  1.  Have dout_* signal maintain the previously valid value until a new valid value is ready.   Effectively adds another latch stage for each output, but I'd like to avoid writing a VHDL wrapper for for all my HLS functions to do this.
  2.  Have multiple outputs share an *_ap_vld valid signal.  Can HLS be directed to use a single shared valid signal for dout_A,B,C which does not assert until all three are valid?
For #2, I could do this by concatenating the three int32 outputs to a single int96 port - this would require a single valid signal, but also a bit cumbersome to deal with combining on C-side and splitting on VHDL side.  I thought perhaps joining the three outputs into a struct would accomplish this:  struct result {dout_A, dout_B, dout_C}.  But HLS treats these no differently, creating three independent outputs with three valid signals.
Thoughts?
Re: Latch function outputs after valid
for 1) you can try register option with ap_vld and see if it does what you need.
#3 question, similar idea -- is there a way to use the "ap_done" signal to indicate that all outputs are valid?
Looks like that will probably work:
set_directive_interface -mode ap_vld -register foo OutData
#pragma HLS interface ap_vld register port=OutData
Re: Let multiple outputs share one *_ap_vld valid signal
  1. ...
I know it's a rather old thread, however, I would like two know if there is a solution for the original question number 2?
Bump
Still need an answer to the question if multiple output vectors can share one valid signal (without DATA_PACK).
Bump
I would welcome an answer to this question, too.
Seems a useful feature.
Bump
Bump
