Loop latency and function latency
I have some bad time to understand the difference between the loop latency and function latency.
Here is the code.
void dist_calc_or0(D_point_or *feature_or,D_point_or *query_or,D_dist1 *dist_temp){
     #pragma HLS INLINE off
    Dtype_l dist_temp_buffer1[D_OR];
    #pragma HLS ARRAY_PARTITION variable=dist_temp_buffer1 cyclic factor=32 dim=1
    #pragma HLS ALLOCATION instances=fmul limit=32 operation
    #pragma HLS ALLOCATION instances=fsub limit=32 operation
    loopForReduceDSP:for(int j=0; j<D_OR;j++){
       #pragma HLS unroll
            dist_temp_buffer1[j]=feature_or->x[j]-query_or->x[j];
            dist_temp->x[j]= dist_temp_buffer1[j]*dist_temp_buffer1[j];
Take the dist_calc_or0 function as an example.
From the vivado_hls.log file, the depth of the loop is 79.
If I am right I'd like to call the depth is the latency of this loop, right?
Why the latency of the function, which is 76 less than that of the loop (79)?
Scholar u4223374
Re: Loop latency and function latency
I assume this function is called in a loop? So the outer loop is the dist_calc_or0 loop?
In that case, you have three things:
Function start interval = 60. Every 60 cycles, the function can be started.
Function latency = 76. It takes 76 cycles to complete the function. However, because some hardware is only used during the second part of the function, the first part can be started while the previous call to the function is still finishing.
Loop pipeline depth = 79. This means that the loop requires a few extra cycles for itself in each iteration (eg. incrementing the loop index) or for other stuff in the loop, so each iteration of the loop actually takes 79 cycles to finish. However, as above, these can be overlapped so the loop can be started every 60 cycles.
Scholar u4223374
Thanks for the explantion.
