Malfunction of ap_int on ofstream's insertion operator with hexadecimal format
I'm new to Vivado HLS and trying to write a test code, and I found a strange behavior about 'ap_int' as follows.
It makes inconvenience on writing test code, since I should handle a lot of long stream data with hex format.
// io manipulation error
int main(){
    using namespace std;
    int int_val = 256;
    ap_int<16> ap_int_val = int_val;
    cout << hex << setw(4) << setfill('0') << int_val    << endl; // 0100 -> OK
    cout << hex << setw(4) << setfill('0') << ap_int_val << endl; // 0x100 -> NG, setfill is ignored
// ofstream error
int main(){
    ofstream ofile("result.txt");
    int int_val = 256;
    ofile << hex << setw(4) << setfill('0') << int_val    << endl; // 0100 -> OK
    ofile << hex << setw(4) << setfill('0') << ap_int_val << endl; // 0256 -> NG, hex is ignored
    ofile.close();
I'm already aware that the reason is in the header files that are provided with Vivado HLS 2019.2 ('ap_int_base.h' and 'ap_private.h').
Is there anyone who knows if there is a plan to fix this problem, or good work around?
Thank you.
Hi @mash-knit
Can you attach a testcase so I can look into the problem in more detail and rule out any issues in your code? If it is a bug, I can flag it with development.
Aoife
@mash-knit ,
I suspect that this too simple of a fix to work, but have you tried casting the "ap_int" to an "int"?  Just a thought.
<< (int)ap_int_val
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
Hi @aoifem
Thank you for your reply.
I attached a VivadoHLS project, which has the test cases in it. And also, I added one more test case with my work-around function ('ap_int_to_hex.h'), to show my expectation.  Please see 'main.cpp' file.
Thank you.
Hi @tedbooth ,
Thank you for your suggestion!
I believe that casting to 'int' will work for many people, but unfortunately not for me. I want to dump 'ap_int<128>', 'ap_fixed<...>', ap_ufixed<...>', and so on. They have the same problem, and are not fit to 'int'.
