definelicht
Missing constructor for streams with non-zero depth
In version 2020.1 of vitis_hls and vivado_hls, the constructor for passing a name to the stream is missing when the depth parameter is specified. If the depth parameter is not specified, the constructor works as expected.
The code below reproduces the error. If the depth parameter is removed (hls::stream<int, 128> changed to hls::stream<int>), the code synthesizes.
This seems like an oversight?
#include <hls_stream.h>
void Read(int const *memory, hls::stream<int, 128> &stream, int N) {
  for (int i = 0; i < N; ++i) {
    #pragma HLS PIPELINE II=1
    stream.write(memory[i]);
void Write(hls::stream<int, 128> &stream, int *memory, int N) {
    memory[i] = stream.read();
void MyKernel(int const *source_memory, int *destination_memory, int N) {
  #pragma HLS INTERFACE m_axi port=source_memory bundle=gmem0
  #pragma HLS INTERFACE m_axi port=destination_memory bundle=gmem1
  #pragma HLS INTERFACE s_axilite port=source_memory bundle=control
  #pragma HLS INTERFACE s_axilite port=destination_memory bundle=control
  #pragma HLS INTERFACE s_axilite port=N bundle=control
  #pragma HLS DATAFLOW
  hls::stream<int, 128> stream("hi");
  Read(source_memory, stream, N);
  Write(stream, destination_memory, N);
ramananr
Yes, the issue with naming the stream is a bug that has been fixed in the upcoming 2020.2 release.
aoifem
Hi @definelicht
Thanks for flagging this as a potential issue. There is some information about this at the following link, under the title Using HLS Streams for Streaming Data
https://www.xilinx.com/html_docs/xilinx2020_1/vitis_doc/programmingvitishls.html
Aoife
**~ Got a minute? Answer our Vitis HLS survey here! ~**
ramananr
