Missing property FREQ_HZ in a Vivado HLS-generated module
I am writing a Vivado HLS module, and I am facing an error message, "Port/Pin property FREQ_HZ does not match between ap_clk and axi_aclk".
I can resolve this problem by adding "FREQ_HZ" in the IP packager.
Can I avoid this error message without adding "FREQ_HZ" manually?
I don't want to open the IP packager whenever the IP is modified.
