Newbie goitzik
Multi threading with Vivado
Vivado2018.2
Analyzing the number of used cores for PnR jobs and I see that in average only 2 processors are used even if we provide 6 CPUs capacity to the job. I see some peak to 4 or 6 CPUs but they last very short.
What should be the expected multi threading ? What are the future plans for continuously multi threading to reduce PnR duration ?
Re: Multi threading with Vivado
Hi goitzik,
You can check the property on how many are set:
>report_param general.maxThreads
Name                         Value  Type         Description
general.maxThreads  2          integer    Maximum threads created for Vivado Value should be >= 1 and <= 8
It is also important to know that for Windows, the Max appears to still be 2:
For Windows systems, the limit is 2; for Linux systems the default is 8
From the UG904:
The maximum number of simultaneous threads varies, depending on the number of processors and task. The maximum number of threads by task is:
• DRC reporting: 8
• Static timing analysis: 8
• Placement: 8
• Routing: 8
• Physical optimization: 8
Newbie goitzik
This is a Linux system.
How can I see what is the default general.maxThreads ?
Hello @goitzik,
By default, the limit is 2 for Windows, and 8 for Linux. This is discussed in more detail on page (7) here:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug904-vivado-implementation.pdf
OK, I hope this helps,
Scott
