piflodrops
Multiple Interface definition in the source code for the same port
I am currently working an a old project that somebody else than me did a couple of years ago (vivado hls 2015.2) and I am facing some problems...
In the following function, the person wrote:
void my_function (  uint32 *buffer_in, uint32 *buffer_out, struct struct_reg *reg ){
#pragma HLS INTERFACE axis register port=buffer_in
#pragma HLS INTERFACE axis register port=buffer_out
#pragma HLS INTERFACE s_axilite port=reg
#pragma HLS INTERFACE ap_none port=reg
/*..... and the rest of the code ...*/
with:
struct struct_reg {
uint64 a;
uint64 b;
Because there are 2 INTERFACE definitions for port 'reg', I have no idea how Vivado HLS synthetise the interface.
When I watch the synthesis report, I never see that the port 'reg' has been synthetise.
And also, when I look how the IP is designed in IP integrator on Vivado, there is absolutly no port 'reg'.
So my question is, do you know how the tool manage to synthetise port 'reg' in such a case? Does it become an internal register or something like that ?
When I watch the vivado_hls.log after synthesis, I get:
@I [RTGEN-500] Setting interface mode on port 'my_function/reg_a' to 's_axilite & ap_none'.
@W [RTGEN-101] Port 'reg_a' with mode 'ap_none' may require an associated data valid signal to correctly communicate with other blocks or a test bench; automatic C/RTL co-simulation may not be able to verify such a port.
Thanks for your help. Hope I've been clear enought.
Pierre
Tags (2)
hpoetzl
Voyager
Voyager
Hey Pierre,
Yes, let me explain what happens here ...
First, HLS interprets struct elements as ports, unless you force it to combine them.
So 'reg' with elements 'a' and 'b' will end up as 'reg_a' and 'reg_b' ports.
Without any INTERFACE #pragma (or directive) the interface for reg would simply become ...
    reg_a : IN STD_LOGIC_VECTOR (63 downto 0);
    reg_b : IN STD_LOGIC_VECTOR (63 downto 0);
... with the default handshake for the function return.
The first INTERFACE #pragma changes that into an AXI-Lite register mapped interface with the following register layout ...
-- ------------------------Address Info-------------------
-- 0x00 : reserved
-- 0x04 : reserved
-- 0x08 : reserved
-- 0x0c : reserved
-- 0x10 : Data signal of reg_a
--        bit 31~0 - reg_a[31:0] (Read/Write)
-- 0x14 : Data signal of reg_a
--        bit 31~0 - reg_a[63:32] (Read/Write)
-- 0x18 : reserved
-- 0x1c : Data signal of reg_b
--        bit 31~0 - reg_b[31:0] (Read/Write)
-- 0x20 : Data signal of reg_b
--        bit 31~0 - reg_b[63:32] (Read/Write)
-- 0x24 : reserved
-- (SC = Self Clear, COR = Clear on Read, TOW = Toggle on Write, COH = Clear on Handshake)
... note that HLS already reports (at least for recent HLS) ...
INFO: [RTGEN 206-500] Setting interface mode on port 'my_function/reg_a' to 's_axilite & ap_none'.
INFO: [RTGEN 206-500] Setting interface mode on port 'my_function/reg_b' to 's_axilite & ap_none'.
... which means that 'ap_none' was automatically added to 's_axilite'.
So the second INTERFACE #pragma is redundant here, but let's see what happens if we change that to ...
#pragma HLS INTERFACE ap_vld port=reg
... HLS will now report ...
INFO: [RTGEN 206-500] Setting interface mode on port 'my_function/reg_a' to 's_axilite & ap_vld'.
INFO: [RTGEN 206-500] Setting interface mode on port 'my_function/reg_b' to 's_axilite & ap_vld'.
... and the register layout will adapt to ...
-- 0x00 : reserved
-- 0x04 : reserved
-- 0x08 : reserved
-- 0x0c : reserved
-- 0x18 : Control signal of reg_a
--        bit 0  - reg_a_ap_vld (Read/Write/SC)
--        others - reserved
-- 0x24 : Control signal of reg_b
--        bit 0  - reg_b_ap_vld (Read/Write/SC)
... with two extra addresses where you can confirm that the provided data is 'valid'.
In general, you can always set a handshake related INTERFACE #pragma together with a protocol/interface related one, as long as there is some kind of handshake in this protocol.
The warning you get at the end that 'ap_none' might cause problems with verification and co-simulation is because there is no good way for the code to know when the data changed, because there is no handshake.
Hope this clarifies,
Herbert
-------------- Yes, I do this for fun!
hpoetzl
Voyager
Voyager
Hey Pierre,
-- 0x00 : reserved
-- 0x04 : reserved
-- 0x08 : reserved
-- 0x0c : reserved
-- 0x18 : reserved
-- 0x24 : reserved
-- 0x00 : reserved
-- 0x04 : reserved
-- 0x08 : reserved
-- 0x0c : reserved
Herbert
piflodrops
Hi Herbert,
Thank you for your answer which is really complete and clear!!!!
Everything seems clear now for me!
Thank you again.
Pierre
hpoetzl
Voyager
Voyager
You're welcome!
All the best,
Herbert
