Need Help:While loop stops without any error message or warning message in Xilinx SDK on KINTEX
I am using KINTEX custom Board [(xc7k325tffg900-2)]  for Hardware Implementation.
My workflow processes involve,
1. Created HLS IP for Error correction Code
2. Integrated HLS IP with microblaze and aurora and generated Bitstream
3. Export Hardware and Launch XSDK.
IN xsdk, Code execution stops in While loop without any error message or warning message.
I am stuck in this work for many days. Please anyone help me and guide me. I am attaching my design.
XSDK Source Code
 int i, m;
 u32 result[102];
 u32 values[204];
 XAurora_decoder LDPC;
 XAurora_decoder  *LDPCPTR=&LDPC;
 XAurora_decoder_Initialize(LDPCPTR,XPAR_AURORA_DECODER_0_DEVICE_ID);
 XAurora_decoder_EnableAutoRestart(LDPCPTR);
 XAurora_decoder_Start(LDPCPTR);
 printf("\r\n Codeword received: \r\n");
 printf("\r\n Error Codeword: \r\n");
 XAurora_decoder_Write_x_Words(LDPCPTR, 0, values, 204);
 while (!XAurora_decoder_IsDone(LDPCPTR));  // CODE STOPS HERE Without displaying any values in CONSOLE
 for(i=0;i<204;i++)
         xil_printf("%d", values[i]);
 printf("\r\n DECODED Codeword: \r\n");
XAurora_decoder_Read_dout_Words(LDPCPTR, 0, result, 102);
Re: Need Help:While loop stops without any error message or warning message in Xilinx SDK on KINTEX
Hi @thaus_015,
Is is stuck in the while loop or does it exits the while loop? Did you consider that XAurora_decoder_IsDone(LDPCPTR) could be at 1 directly (when entering the while loop)?
Did you try to debug step by step?
Florent
Florent
Sorry , Update : I am trying microblaze and aurora with custom board :xc7k160tffg677-2.
Yes,  i have tried step by step. But it is stucking in while loop.
The same design, i have tried with only microblaze with Kintex custom board (xc7k325tffg900-2) .Its working fine. I am attaching my design
I am pasting FULL SOURCE CODE
/************************** Function Prototypes ******************************/
int XLlFiforx(XLlFifo *InstancePtr, u16 DeviceId);
int RxReceive(XLlFifo *InstancePtr, u32 *DestinationAddr, int end);
int decoder(u32 *codeword);
/************************** Variable Definitions *****************************/
XLlFifo FifoInstance;
u32 DestinationBuffer[204];
int main()
    int Status;
    xil_printf("Entering RX loop\r\n");
    Status = XLlFiforx(&FifoInstance, FIFO_DEV_ID);
    if (Status != XST_SUCCESS)
        xil_printf("Axi Streaming FIFO Test Failed\n\r");
        return XST_FAILURE;
    xil_printf("Successfully ran Axi Streaming FIFO \n\r");
    return XST_SUCCESS;
    XLlFifo_Config *Config;
    int Status,m;
    Status = XST_SUCCESS;
    Config = XLlFfio_LookupConfig(DeviceId);
    if (!Config)
        xil_printf("No config found for %d\r\n", DeviceId);
        return XST_FAILURE;
    Status = XLlFifo_CfgInitialize(InstancePtr, Config, Config->BaseAddress);
        xil_printf("Initialization failed\n\r");
        return Status;
    Status = RxReceive(InstancePtr,DestinationBuffer,204)
    decoder(DestinationBuffer);
        xil_printf("Receiving data failed");
        return XST_FAILURE;
    return Status;
 int i, m;
 u32 result[102];
 XAurora_decoder_Write_x_Words(LDPCPTR, 0, codeword, 204);
 for(i=0;i<204;i++)
         xil_printf("%d", DestinationBuffer[i]);
    for(m=0;m<102;m++)
     xil_printf("%d", result[m]);
int RxReceive (XLlFifo *InstancePtr, u32* DestinationAddr,int end)
    int i;
    //int Status;
    u32 RxWord;
    static u32 ReceiveLength=0;
    xil_printf(" Receiving data ....\n\r");
    /* Read Receive Length */
    while(1)
    ReceiveLength = (XLlFifo_iRxGetLen(InstancePtr))/WORD_SIZE;
    xil_printf("ReceiveLength: %d",ReceiveLength);
         if (ReceiveLength > 0)
            for ( i=0; i < end; i++)
              RxWord = 0;
              RxWord = XLlFifo_RxGetWord(InstancePtr);
             *(DestinationAddr+i) = RxWord;
             xil_printf("data : %d\r\n",*(DestinationAddr+i));
    break;
    return XST_SUCCESS;
Its just printing "Error Codeword" afterthat It is stuck in the while loop and nothing else printed.
Hi @thaus_015,
Could you give more information about where it is stuck?
I guess in the function: XAurora_decoder_Read_dout_Words(LDPCPTR, 0, result, 102);?
Did you correctly updated the hdf in SDK file when you changed the target board?
Florent
Florent
In function int decoder(u32 *codeword)
I am stuck in first While function itself :XAurora_decoder_Write_x_Words(LDPCPTR, 0, DestinationBuffer, 204);
1. Suppose if i comment that [//while loop] means, Its going to next While loop : XAurora_decoder_Read_dout_Words(LDPCPTR, 0, result, 102);
2. Suppose if i comment Both while loop functions
    a. XAurora_decoder_Write_x_Words(LDPCPTR, 0, DestinationBuffer, 204);
    b. XAurora_decoder_Read_dout_Words(LDPCPTR, 0, result, 102);
Its printing all final values as  ZERO`s.
Did you correctly updated the hdf in SDK file when you changed the target board? Yes, I have correctly updated
Hi @thaus_015,
Could you debug more in the XAurora_decoder_Write_x_Words?
Florent
Florent
I have checked the Function :XAurora_decoder_Write_x_Word, added   xil_printf statements, its printing
u32 XAurora_decoder_Write_x_Words(XAurora_decoder *InstancePtr, int offset, int *data, int length) {
    Xil_AssertNonvoid(InstancePtr != NULL);
    Xil_AssertNonvoid(InstancePtr -> IsReady == XIL_COMPONENT_IS_READY);
    int i;
    if ((offset + length)*4 > (XAURORA_DECODER_A_ADDR_X_HIGH - XAURORA_DECODER_A_ADDR_X_BASE + 1))
        return 0;
    xil_printf("Writing Words into Decoder");
    for (i = 0; i < length; i++) {
        *(int *)(InstancePtr->A_BaseAddress + XAURORA_DECODER_A_ADDR_X_BASE + (offset + i)*4) = *(data + i);
    xil_printf("EXIT");
    return length;
Its working : In console I have got result like that: Error Codeword:
Writing Words into DecoderEXIT
XAurora_decoder_Write_x_Words(LDPCPTR, 0, values, 204);  Its working
 while (!XAurora_decoder_IsDone(LDPCPTR)); Its stucking into WHILE LOOP
 for(i=0;i<204;i++)
         xil_printf("%d", values[i]);       //NOTHING PRINTING
XAurora_decoder_Read_dout_Words(LDPCPTR, 0, result, 102); //
