Observer zslwyuan
No Ouput in HLS FIFO Interface of Simple Code
Dear all,
    Hi! I am trying to generate signals into a fifo with the following very simple code:
void InGenBlock_1(int output[2000])
#pragma HLS INTERFACE ap_fifo port=output
    int i,a,b;
    for (i=0;i<2000;i++)
        output[i] = i;
    Accordingly, I build a project including the generated HLS IP Core as shown below:
Screenshot from 2019-01-16 23-32-53.png    ================================
        And then I do the behavioral simulation but get nothing in the output port of data, with following Tcl script. The simulation result is also shown below:
add_force {/design_1_wrapper/output_r_full_n_0} -radix hex {0 0ns}
add_force {/design_1_wrapper/sys_clock} -radix hex {1 0ns} {0 5000ps} -repeat_every 10000ps
add_force {/design_1_wrapper/ap_start_0} -radix hex {0 0ns}
add_force {/design_1_wrapper/reset_rtl} -radix hex {1 0ns}
run 10 us
add_force {/design_1_wrapper/reset_rtl} -radix hex {0 0ns}
run 10 us
add_force {/design_1_wrapper/ap_start_0} -radix hex {1 0ns}
run 10 us
      When I try the conventional ap_memory interface, there are available outputs. I am confused whether there is any inappropriate in my code or configuration?
      THANKS A LOT in advance for your time and suggestions!
Tingyuan
Observer zslwyuan
Re: No Ouput in HLS FIFO Interface of Simple Code
@evant_nq
@xilinxacct
Dear all,
    Thanks for your time!! I have found the solution here: https://forums.xilinx.com/t5/Vivado-High-Level-Synthesis-HLS/HLS-Integrator-fifo-interface/td-p/847004
    0-0 Interesting HLS....
    Thanks a lot!!
Tingyuan
Teacher xilinxacct
@zslwyuan
Have you tried hls::stream instead of an array? These natural lend themselves to FIFOs.
Hope that helps
If so, please mark as solution accepted. Kudos also welcomed.
What happens if you reduce the array size to 10?
Make it smaller just as a good practice when something doesn't seem to be working properly. Makes the simulation easier to follow.
But a quick bit of math, it looks like your clock period is 10ns (10,000ps) That's 100Mhz
You start the block for 10us, which is 10,000ns. 10,000/10 = 1000 clock cycles.
I would confirm it's running for the full 2000 cycles. If you see the latency it takes 2001 cycles for the output, so i suspect that might be what's happening in the simulation.
Observer zslwyuan
@xilinxacct
Thanks a lot for your suggestion! However, it does not work.
I wonder whether there is any difference between FIFO and STREAM? Or maybe can you point out the problem in the source code?
I wonder whether there is any successful standalone HLS example with FIFO?
Thanks again for your time!
Tingyuan
Observer zslwyuan
@evant_nq
Dear Evant,
    Thanks for your suggestions and I have tried all of them but sadly, they still do not work.
    Is there any problem in my source code or could you provide a similar example that works successfully?
Tingyuan
Observer zslwyuan
@evant_nq
@xilinxacct
Dear all,
    Thanks a lot!!
Tingyuan
