Participant twoism_
OpenCL kernel with async_work_group_copy()
I'm trying to synthesize an OpenCL kernel for matrix multiplication. The kernel works, but if I change the memory copy loop:
__kernel void __attribute__ ((reqd_work_group_size(WG_SIZE_0, 1, 1)))
mmul(__global const data_t *ma, __global const data_t *mb, __global data_t *mc) {
	// Input and output rows buffer
	__local data_t a_row[WG_SIZE_0];
	__local data_t c_row[WG_SIZE_0];
	// Matrix A row index
	const int i = get_global_id(0);
	// Copy row i (global_id index) form matrix A
	for (int j = 0; j < WG_SIZE_0; ++j) {
		a_row[j] = ma[i * WG_SIZE_0 + j];
with:
	async_work_group_copy(a_row, ma + i * WG_SIZE_0, WG_SIZE_0, 0);
	barrier(CLK_LOCAL_MEM_FENCE);
The design becomes un-synthesizable, with the following errors:
@E [SYNCHK-11] mmul_OpenCL/srcs/mmul.cl:5: in function 'mmul': Variable '.01.reg2mem.priv.i.i' has an unsynthesizable type '[8 x i32 addrspace(1)*]*' (possible cause(s): pointer to pointer or global pointer).
@E [SYNCHK-22] mmul_OpenCL/srcs/mmul.cl:5: in function 'mmul': memory copy is not supported unless used on bus interface possible cause(s): non-static/non-constant local array with initialization).
@I [SYNCHK-10] 2 error(s), 0 warning(s).
@E [HLS-70] Synthesizability check failed.
Any ideas why this isn't working?
Re: OpenCL kernel with async_work_group_copy()
The way async_work_group_copy is used in your code violates the OpenCL Spec. Below statement is copied from OpenCL 1.2 spec (page 278 https://www.khronos.org/registry/cl/specs/opencl-1.2.pdf ). In your code, each work-item passes a new source pointer values to async_work_group_copy fucntion.
async copy is performed by all work-items in a workgroup and this built-in function must therefore be encountered by all work-items in a work-group executing the kernel with the same argument values; otherwise the results are undefined.
Cheers,
Jim
What is the actual data type of data_t? Can you please attach the complete code so we can try it out?
@twoism_ wrote:
with:
Cheers,
Jim
Participant twoism_
#define WG_SIZE_0 8
typedef int data_t;
Participant twoism_
The problem arises when I substitute the memory copy loop with the async_work_group_copy call. The rest of the code is a plain matrix multiplier. You can replicate (and isolate) the error by synthesizing with the following snippet:
mmul.h
#ifndef MMUL_H
#define MMUL_H
#define WG_SIZE_0 8
typedef int data_t;
#endif
mmul.cl
#include <clc.h>
#include "mmul.h"
	// Unused
	//data_t j = get_global_id(1);
//	for (int j = 0; j < WG_SIZE_0; ++j) {
//		a_row[j] = ma[i * WG_SIZE_0 + j];
	// ensure all values have been read before begin the next stage
Errors:
@I [HLS-10] Checking synthesizability ...
@E [SYNCHK-11] mmul_compute_unit:62: in function '__AESL_work_groupA': Variable '.0.reg2mem.priv.i.i' has an unsynthesizable type '[8 x i32 addrspace(1)*]*' (possible cause(s): pointer to pointer or global pointer).
@W [SYNCHK-77] The top function '__AESL_work_groupA' (mmul_compute_unit:62) has no outputs. Possible cause(s) are: (1) Output parameters are passed by value; (2) intended outputs (parameters or global variables) are never written; (3) there are infinite loops.
@I [SYNCHK-10] 1 error(s), 1 warning(s).
Cheers,
Jim
