Performance issues between Kintex-7 FPGA KC705 and Xc7ck160tffg676-2
I am trying error correction Function with Kintex-7 FPGA KC705 and with custom board Xc7ck160tffg676-2.
Its working fine with Kintex-7 FPGA KC705, but its not printing any result with custom board. Please help me.
Process 1: Includes for Kintex-7 FPGA KC705,
1. Created HLS IP for error correction Function
2. Integrated HLS IP with microblaze through VIVADO INtegrator
3. Generated output
Finally, got output.
Process 2: Includes for Xc7ck160tffg676-2,  Code is stucking in While LOOP
2. Integrated HLS IP with microblaze and aurora through VIVADO INtegrator
3. Generated output
Unable to print output
SOURCE CODE
 * Decoder.c
 *  Created on: 06-Nov-2017
 *      Author: Optics2015A
 * RX2.c
 *  Created on: 31-Oct-2017
 * RX.c
#include <stdio.h>
#include "math.h"
#include "xparameters.h"
#include "xil_exception.h"
#include "xstreamer.h"
#include "xil_cache.h"
#include "xllfifo.h"
#include "xstatus.h"
#include "xil_printf.h"
#include "xuartlite.h"
#include "XAurora_decoder.h"  /// HLS IP
/**************************** Type Definitions *******************************/
/***************** Macros (Inline Functions) Definitions *********************/
#define FIFO_DEV_ID           XPAR_AXI_FIFO_0_DEVICE_ID
#define WORD_SIZE 4            /* Size of words in bytes */
#define MAX_PACKET_LEN 4
#define NO_OF_PACKETS 8
#define MAX_DATA_BUFFER_SIZE NO_OF_PACKETS*MAX_PACKET_LEN
#undef DEBUG
/************************** Function Prototypes ******************************/
int XLlFiforx(XLlFifo *InstancePtr, u16 DeviceId);
int RxReceive(XLlFifo *InstancePtr, u32 *DestinationAddr);
XLlFifo FifoInstance;
//u32 DestinationBuffer[MAX_DATA_BUFFER_SIZE * WORD_SIZE];
u32 DestinationBuffer[204];
int main()
    //u32 RxWord;
    int Status;
    xil_printf("Entering RX loop\r\n");
    //while(1)
    Status = XLlFiforx(&FifoInstance, FIFO_DEV_ID);
    if (Status != XST_SUCCESS)
        xil_printf("Axi Streaming FIFO Test Failed\n\r");
        return XST_FAILURE;
    xil_printf("Successfully ran Axi Streaming FIFO \n\r");
    return XST_SUCCESS;
    XLlFifo_Config *Config;
    int Status;
    Status = XST_SUCCESS;
    /* Initialize the Device Configuration Interface driver */
    Config = XLlFfio_LookupConfig(DeviceId);
    if (!Config)
        xil_printf("No config found for %d\r\n", DeviceId);
        return XST_FAILURE;
     * This is where the virtual address would be used, this example
     * uses physical address.
    Status = XLlFifo_CfgInitialize(InstancePtr, Config, Config->BaseAddress);
        decoder(DestinationBuffer);
        xil_printf("Initialization failed\n\r");
        return Status;
    /* Receive the Data Stream */
    while(1) {
    Status = RxReceive(InstancePtr, DestinationBuffer);
        xil_printf("Receiving data failed");
        return XST_FAILURE;
    return Status;
int decoder(u32 *DestinationBuffer)
 int i, m;
 u32 result[102];
 XAurora_decoder LDPC;
 XAurora_decoder  *LDPCPTR=&LDPC;
 XAurora_decoder_Initialize(LDPCPTR,XPAR_AURORA_DECODER_0_DEVICE_ID);
 XAurora_decoder_EnableAutoRestart(LDPCPTR);
 XAurora_decoder_Start(LDPCPTR);
 printf("\r\n Error Codeword: \r\n");
 XAurora_decoder_Write_x_Words(LDPCPTR, 0, DestinationBuffer, 204);
 while (!XAurora_decoder_IsDone(LDPCPTR));   // STUCKING AT WHILE LOOP
 for(i=0;i<204;i++)
         xil_printf("%d", DestinationBuffer[i]);
 printf("\r\n DECODED Codeword: \r\n");
XAurora_decoder_Read_dout_Words(LDPCPTR, 0, result, 102);
    for(m=0;m<102;m++)
        xil_printf("%d", result[m]);
           return 0;
    //binary_to_decimal(result);
int power_func(int c, int d)
      int value = 1;
      int count = 1;
      while(count <= d)
            value = value * c;
            count++;
      return value;
int binary_to_decimal(u32 *result)
     int dec_num1 = 0;
     int dec_num2 = 0;
     int dec_num3 = 0;
     int a = 0, b=0,c=0,i,j,k;
     for(i = 7; i >= 3; i--)
            dec_num1 = (result[i] * power_func(2, a)) + dec_num1;
            a++;
     printf("\n\t %d", dec_num1);
     b=0;
     for(j = 28; j >= 11; j--)
            dec_num2 = (result[j] * power_func(2, b)) + dec_num2;
            b++;
     printf("\n\t %d", dec_num2);
     for(k = 36; k >= 32; k--)
            dec_num3 = (result[k] * power_func(2, c)) + dec_num3;
            c++;
    printf("\n\t %d", dec_num3);
      printf("\n");
      return 0;
int RxReceive (XLlFifo *InstancePtr, u32* DestinationAddr)
    int i;
    //int Status;
    u32 RxWord;
    static u32 ReceiveLength;
    //xil_printf(" Receiving data ....\n\r");
    /* Read Receive Length */
    ReceiveLength = (XLlFifo_iRxGetLen(InstancePtr))/WORD_SIZE;
    xil_printf("ReceiveLength: %d",ReceiveLength);
    if (ReceiveLength > 0) {
    //xil_printf("rxlen = %d\r\n", ReceiveLength);
    /* Start Receiving */
    for ( i=0; i < ReceiveLength; i++)
        RxWord = 0;
        RxWord = XLlFifo_RxGetWord(InstancePtr);
        //xil_printf("Occ[%d]: %d\r\n", i, XLlFifo_iRxOccupancy(InstancePtr));
        /*if(XLlFifo_iRxOccupancy(InstancePtr))
        *(DestinationAddr+i) = RxWord;
        xil_printf("received data : %d\r\n",*(DestinationAddr+i));
    //xil_printf("%s", (char *)(DestinationAddr));
/*    Status = XLlFifo_IsRxDone(InstancePtr);
    if(Status != TRUE)
        xil_printf("Failing in receive complete ... \r\n");
        return XST_FAILURE;
    */return XST_SUCCESS;
