rdemara
PicoZed in the Device Selection GUI?
Any way to get the PicoZed 7030 to show up in the Device selection GUI?
Here's what I see in HLS, I'm running 2014.4.1:
It shows up in Vivado:
rdemara
I figured it out. Instead of selecting a board, you can select the part directly (xc7z030sbg485-1), in my case it's:
rdemara
pratham
@rdemara You can get your your board in the list, Let me know if you would like to see your board in the selection list
-Pratham
rdemara
@pratham, yes that would be great! I'm using the picozed w/ carrier card from Avnet. I thought by adding it to Vivado it would be available in HLS but it isn't.
pratham
@rdemara Check your message.
-Pratham
