aronfeher
Please help with custom filter IP
Hello everyone.
Recently I wanted to create a simple balancing controller system with ZYBO board in Vivado and HLS. The plan is as follows: I measure the angle with a potmeter, and conveert the analog values with XADC. After conversion, I transform the values to angles. So far it works.
I've created a custom IP in HLS to filter the input data but I only get 0.000 as return value after the filtering.
I've attached the cpp file used in HLS, which was previously tested, and it works.
I've also attached main c file used in SDK.
The problem is, I don't know where to look for the problem, so any help would be appreciated.
With regards,
Fehér Áron.
muzaffer
@aronfeher verify your float_to_u32 and reverse functions carefully and check the values which go into them during runtime to see if you get what you expect. Also I think your original code of waiting till done is set and reading the output makes more sense than the current loop. Why did you change it?
muzaffer
aronfeher
Thank you. Somehow I left the return type as unsigned int, and no matter how many times I went over it, I did not see it.
