Post-addition of MAC operation not mapped to DSP (fixed point operands)
Hi everyone,
I'm unsuccessfully trying to map a multiply accumulate (mac) operation on a DSP48E block in Vivado HLS 2018.2 (targeting a ZCU104 board). In details, I'm unable to map the post-adder operation to the DSPs, which is always mapped to LUTs instead. I believe all the operands in my code follow this checklist, that's why I'd like some extra advice in order to achieve my goal.
The following code snippet illustrates my problem:
typedef ap_fixed<16, 7, AP_RND_ZERO, AP_SAT_SYM> DataType;
typedef ap_fixed<18, 9, AP_RND_ZERO, AP_SAT_SYM> AccumType;
template <int NumIter, int VectLength>
void MAC(hls::stream<DataType> &x1,
         hls::stream<DataType> &x2,
         hls::stream<DataType> &w,
         hls::stream<DataType> &y1,
         hls::stream<DataType> &y2) {
  AccumType y1_mac = 0;
  AccumType y2_mac = 0;
  for (int i = 0; i < NumIter; ++i) {
    for (int j = 0; j < VectLength; ++j) {
#pragma HLS PIPELINE II=1
      if (j == 0) {
        y1_mac = 0;
        y2_mac = 0;
      auto w_tmp = w.read();
      auto mac1 = x1.read() * w_tmp;
      auto mac2 = x2.read() * w_tmp;
      mac1 += y1_mac;
      mac2 += y2_mac;
#pragma HLS RESOURCE variable=mac1 core=DSP48
#pragma HLS RESOURCE variable=mac2 core=DSP48
      y1_mac = mac1;
      y2_mac = mac2;
      if (j == VectLength - 1) {
        y1.write(y1_mac);
        y2.write(y2_mac);
I've already tried different approaches, but all of them failed (they just mapped only the multiplication to the DSP, not the post-addition):
  • different accumulate type bitwidth, both narrowed (16bit) and wider (32) (I still need those saturation and quantization modes though);
  • avoided using the intermediate variables (mac1 and mac2) and the resource pragmas;
  • output streams set to AccumType (even though I'd prefer not go with this solution, which anyway doesn't work);
  • this solution using a "Register" class.
Is there any coding guideline I haven't found/followed yet? Why do I only get the multiplication and not the full mac operation? Do the saturation and quantization modes prevent the mapping? Maybe the last if-statement is another reason why the mapping is not happening?
Any help or tip will be highly appreciated,
Best,
Stefano
Re: Post-addition of MAC operation not mapped to DSP (fixed point operands)
I think it has to do with the rounding operation.  AP_TRN seems to work
//typedef ap_fixed<16, 7, AP_RND_ZERO, AP_SAT_SYM> DataType;
//typedef ap_fixed<18, 9, AP_RND_ZERO, AP_SAT_SYM> AccumType;
typedef ap_fixed<16, 7, AP_TRN, AP_SAT_SYM> DataType;
typedef ap_fixed<18, 9, AP_TRN, AP_SAT_SYM> AccumType;
         hls::stream<AccumType> &y1,
         hls::stream<AccumType> &y2) {
	AccumType y1_mac;
	AccumType y2_mac;
  iLoop: for (int i = 0; i < NumIter; ++i) {
    jLoop: for (int j = 0; j < VectLength; ++j) {
      auto x1_tmp = x1.read();
      auto x2_tmp = x2.read();
      if (j == 0) {
    	y1_mac = 0;
    	y2_mac = 0;
      y1_mac += (x1_tmp * w_tmp);
      y2_mac += (x2_tmp * w_tmp);
    y1.write(y1_mac);
    y2.write(y2_mac);
回复: Post-addition of MAC operation not mapped to DSP (fixed point operands)
Hi @stefanoribes ,
     Can you provide your source code include the .pp and .h file ?
Wen
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
There's not so much else to add: the algorithm is mac-ing VectorLength 'new' elements for NumIter times. The if-statements perfectly flatten the loops and generate a pipeline with II=1 (which is exactly what I wanted to achieve here; no concerns on this).
A top function could be as simple as the following:
void MAC_top(hls::stream<DataType> &x1,
  MAC<16, 512>(x1, x2, w, y1, y2);
(shall I zip a small HLS project with the two files?)
BR,
Stefano
	AccumType y1_mac;
	AccumType y2_mac;
      if (j == 0) {
    	y1_mac = 0;
    	y2_mac = 0;
    y1.write(y1_mac);
    y2.write(y2_mac);
That's correct. The issue seems to be with rounding operation. AP_RND also seems to work instead of AP_RND_ZERO
Nithin
Hi @stefanoribes
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Aoife
Hi all,
thank you all for the suggestions and in particular @p27803 and @nithink: it was indeed the rounding. I preferred not touching the rouding mode because of the algorithm I'm implementing, but it really seems the only way to fully exploit the DSPs. Thanks again.
BR,
Stefano
Hi @stefanoribes ,
    Happy to see the workround was found. When I dug into UG902, a tip was found saying:
    Quantization and overflow modes that do more than the default behavior of standard hardware arithmetic (wrap and truncate) result in operators with more associated hardware. It costs logic (LUTs) to implement the more advanced modes, such as round to minus infinity or saturate symmetrically
    In addition, the following example shows that the typedef statement for the accumulation variable uses the AP_TRN quantization mode. I guess the accumulating operation uses truncation mode to consume less resources.
#include "ap_fixed.h"
typedef ap_ufixed<10,8, AP_RND, AP_SAT> din1_t;
typedef ap_fixed<6,3, AP_RND, AP_WRAP> din2_t;
typedef ap_fixed<22,17, AP_TRN, AP_SAT> dint_t;
typedef ap_fixed<36,30> dout_t;
dout_t cpp_ap_fixed(din1_t d_in1, din2_t d_in2) {
static dint_t sum;
sum += d_in1;
return sum * d_in2;
Wen
