joancab
Problem reading IP-written data from Linux userspace
I have an HLS IP that writes into PS memory using a master AXI port. Then I want to read that data from a Linux app.
The IP block seems to work, looking at the following ILA capture:
Although locations are not consecutive (here there is an increment of 0x50), all consecutive positions are eventually written. Below shows, for example, 0x7F00_0004 being written:
To read that memory from Linux I use the /dev/mem pseudo-driver and mmap. In a nutshell, I do:
int fd = open("/dev/mem", O_RDWR | O_SYNC);
u32 *mem = mmap(NULL, SIZE, PROT_READ | PROT_WRITE, MAP_SHARED, fd, page_base);
memcpy(buff, mem, SIZE);
Where:
SIZE is the memory area size in bytes (8k)
page_base is the physical address (0x7F00_0000)
buff is a u32 pointer
Now the weirdest about it: I first pre-write buff[] with 0x0a0a0a0a, 0x0b0b0b0b ... 0x0f0f0f0f to recognize changes. When I run the application, only one every four words are written. And data written is not even in the right location: 0x7F00_0000 should have 0x8629e8e4 but that value appears at buff[44]. also, according to ILA, 0x7F00_0004 should contain 0xa7a392dd but is unchanged and that value appears at buff[76].
joancab
I'm thinking it could be a problem with address alignment at the master AXI side. All successful writes are aligned to 16 bytes (address 0xXXX.XX0), is it possible to change that in an HLS block?
randyh
joancab
@randyh
Thanks, that helps a bit, although at first it doesn't seem to work. I re-built the HLS IP with 0 alignment:
I also have 16 outstanding writes that I believe is enough
I'm still getting data written at one out of four 32-bit words, apparently:
The above is obtained with mmap and memcpy to an array in user space.
I checked with ILA that the addresses showing 0 are written something else.
Originally I wrote 32-bit words, in this case I also changed to writing bytes to see if that was the reason, but doesn't seem to be.
I rebuilt everything: HLS IP, Vivado bitstream, linux images, application.
joancab
I changed the IP to write bytes instead of u32 and tried with alignment 1 (byte) on the HLS settings, I get the same results: 4 bytes are written following 12 aren't:
shahzadb
Hi Joan,
   Can you please try to keep the alignment on IP side at-least which you can achieve in host code. Can you please try to align IP on 4-byte ( 32-bits) and see how it works?
joancab
@shahzadb That would be weird that 4-byte alignment does what 1-byte doesn't.
I tried, weirdest things I have seen, below settings:
Similar results:
shahzadb
@joancab  The Alignment size is in bits so I was expecting a value of 32 not 4. Please check here :https://www.xilinx.com/html_docs/xilinx2020_2/vitis_doc/lls1585342611108.html#lls1585342611108__ae410299
joancab
Holy moly, then the name m_axi_alignment_byte_size is misleading. It makes people think of size in bytes.
joancab
I set the alignment to 8 (bits) as my current IP block version addreses bytes:
Result, again 4 bytes written, 12 not.
Interestingly, if I copy the mapped area into an array with:
memcpy((void *)(buff), (void *)(mem), 400);
And print the array values with
printf("%02X%s", buff[i], ((i%16)==15)? "\n" : " ");
I get the above values, while if I use the pointer to the mapped memory (mem) like:
printf("%02X%s", mem[i], ((i%16)==15)? "\n" : " ");
I get slightly different results (?) where only one byte (first column) every 16 is different (??)
Is memcpy not working properly?
joancab
And similar for an alignment of 32. It seems only addresses type 0xXXXX_XX0X are written (or read back)
joancab
Back to this problem, I tried an even simpler IP core that just writes 16 words in consecutive addresses:
void test(	uint32_t* dout	){
#pragma HLS INTERFACE m_axi port=dout offset=off
#pragma HLS INTERFACE s_axilite port=return
	uint32_t i;
	uint32_t d = 0x0;
	for(i=0; i<16; i++){
		dout[0x1fc00000 + i] = d;
		d += 0x01010101;
And ILA shows it should be writing those values (0x00000000, 0x01010101 ... 0x0f0f0f0f)
But what I get, again when reading from Linux user space is this below. Again it looks like skipping 3 every four words.
So I'm beginning to think the problem is Linux (?)
