Visitor abendig
Problems with UG 871 Vivado HLS Tutorial -Using HLS IP in a Zynq Processor Design
Hello
I'm hope i'm in the right forum.
So at the moment i want to do the Vivado HLS tutorial, especially this is the only tutorial who use HLS and the IP Integrator.
First the Lab files for "Using HLS iP in a Zynq Processor Design"  was incomplete but this probelm was solve with the last update of the files, but now i think the files are wrong
I want to archive the Lab #2 Streaming data between Zynq CPU and HLS accelerator blocks but when i go through the tutorial i get some error messages and warning messages.
So my first question is somewhere out there who programm successfully the tutorial?
The error messages are from the type BD41-66 Error running propagate TCL procdure : invalid comman name
and also i think the tutorial is wrong with the transform length of the fft block.
Kind regard
Achim
Tags (4)
Re: Problems with UG 871 Vivado HLS Tutorial -Using HLS IP in a Zynq Processor Design
I do not have any problem on ug871. Could you provide more details?
Visitor abendig
Have you try this Lab with Zynq and the IP Integrator?
As i write in my first messages.
I think the length of the IP Blocks are wrong and
I get this strange TCL Message
BD41-66 Error running propagate TCL procdure : invalid command name
Achim
Are you using 2013.1 or 2013.2? This lab is supposed to be used with 2013.1 for IP Integrator flow. Did you see any error at the end of HLS IP generation (Step-1 of Lab-2)
Debraj
