definelicht
Query version of HLS tool
Vitis 2020.1 introduces breaking changes (#1, #2) with no forward or backwards compatible fix, so it's necessary to emit different code depending on which tool is used (vitis_hls or vivado_hls), and/or which version of the tool used to run synthesis.
Is there a way to query which version of the HLS tool is being run from the preprocessor?
I'm looking for something in the spirit of:
#if __VITIS_HLS__
// vitis_hls-compatible implementation
#elif __VIVADO_HLS__
// vivado_hls-compatible version
#else
// simulation/CPU version
#endif
It is possible to pass something manually using cflags in the synthesis script, but this does not work for library code, where it could be run in any number of environments.
definelicht
For anyone wondering, this was answered by @ramananr in another thread:
Vitis HLS 2020.2 will contain the predefined macro "__VITIS_HLS__" and so users can use "#ifdef __VITIS_HLS__" to ensure that the code block contained in the ifdef gets executed only when running Vitis HLS.
But unfortunately, previous versions of Vitis HLS and Vivado HLS do not contain such macros and therefore, if you wish to use such macros in your library, you will have to instruct your users to add "-D__VITIS_HLS__" in the -cflags and -csimflags arguments of the add_files command.
baltam
I don't know whether VITIS makes available a way to query about the version but time ago I had a similar problem with vivado HLS which did not have any direct way.
Pls, check if this helps
https://forums.xilinx.com/t5/High-Level-Synthesis-HLS/tcl-scripting-how-get-the-vivado-hls-version-from-inside-the/m-p/804197#M10599
definelicht
Thanks for the suggestion! I'm developing library code, some of which consists of headers included directly by user code. This means that I don't have control of how the code is included and compiled. So the only way for this to work consistently is if the tool itself exposes the version running
ramananr
definelicht
