Questions about the library function hls::Harris()
Hello, experts and scholars.
When I called the library function hls::Harris() in HLS, I found that I couldn't call it at all. When I entered the library function I found the following phenomenon:1.PNG
A FindMax() function is missing from the menu bar on the right, but it is available in the entire hls_video_harris.h file. I would like to ask: Is this a library function error? Or no error, how to use this library function?
Re: Questions about the library function hls::Harris()
Hello zz110,
Since this is an HLS question I am moving it to the Vivado High-Level Synthesis board to get you to a place that can supply you with an answer.
This board is focused on Open Source and Community Projects and I thin the Vivado HLS board is better suited to your needs.
Hello forrestp,
Thank you very much for your reply.
I will take a look at the contents of this library function and wait for your further reply.
