Visitor piflodrops
Read ap_int data from CSV file created via ILA export.
In vivado HLS simulation (2017.4), I need to read data from a csv file created via the export ila in the hardaware manager on Vivado.
One of the data that I must read is an ap_int<256> and here is the shape of the csv file I want to read :
Sample in Buffer,Sample in Window,TRIGGER,data_i_need_to_read[255:0]
0,0,0,05d14cc4af723fbc2bd24259000000000284f73bcf7efffffffff9cf26d7c4f9
1,1,0,06d0c0eff7833fa2d5a5b8e2ffffffffff49b3f4b019fffffffff7e7e2506f24
2,2,0,07cfc774be3a3f857fa9c1b9fffffffffbab904566a1fffffffff91fcf9bb6da
My main goal is to ba able to read data_i_need_to_read. To do so I have tried to use classic C function like fscanf :
int s_in_buffer, s_in_window, trigger;
ap_int<256>  d_exp_im_fifo_0;
 fscanf(ptr_fid, "%d,%d,%d,%064x",s_in_buffer, s_in_window, trigger, d_exp_im_fifo_0);
I've also tried to use c++ like : csv_file >> s_in_buffer >>  s_in_window >> trigger >> d_exp_im_fifo_0;
But the compilator always send me an error :
error: cannot pass objects of non-trivially-copyable type 'class ap_int<256>' through '...'
So my question is, what is the good way to read this kind of data ?
My question had already been asked here, but nobody could answer I guess.
https://forums.xilinx.com/t5/Vivado-High-Level-Synthesis-HLS/A-question-about-reading-data-from-an-external-file/m-p/726301#M7426
Thank you for helping me.
See You,
Pierre
Re: Read ap_int data from CSV file created via ILA export.
Are you using this for a test bench?
i think the issue you are having is that fscanf doesn't understand the HLS ap_ints.
You likely should read it in as a string, and then write a function to convert the string into a 256bit integer,
I would do something where I would convert the string to a decimal value between 0-15 starting at the MSB, and each time I see a new char shift it over by 4 bits and add the previous value.
char text[64];
int val_2_add;
for (i=0; i <64; i++) {
if(text[i] >= 48 | val_2_add[i] <= 57) {
     val_2_add = (text[i]  -48);
} else if ( <Same but for a - f >) {
d_exp_im_fifo_0 = (d_exp_im_fifo_0 << 4) + val_2_add ;
I believe that should get some arbitrary sized bit vector from a file. There might be an HLS function to do this, but I didn't see it so this should work instead.
char text[64];
int val_2_add;
Visitor piflodrops
Yes I am using it for a Test Bench.
In deed your solution seems to be the best one since there is no HLS function available to read ap_int bigger than 64bits.
If you here about it, let me know :)
Thank you!
